Question about Alpine CDA-9855 CD Player
Blew the fuse
I had my battery changed in my car. but put the positive and the negative in the wrong spots and blew the fuse in my radio i changed the fuse the the radio still does not work
    Problem Solver:
  • 14 Answers
YOU CHECK THE CAR FUSE...BUT THE STEREO HAVE ANOTHER FUSE. CHECK IT IF PROBLEM PERSIST.... I´M SORRY BUT I THINK YOU BLOWIT ,YOU MUST GO TO REPAIRED SOME TIMES BLOW A THIN LINES INSIDE THE STEREO AND REPAIRED THOSE WORK AGAIN AND POWER AMP IN THE STEREO BLOW TOO. GOOD LOCK!!!!
Posted on Feb 17, 2007
Diagnosis for battery terminal wrongly fitted
Do you know what make, model, year of vehicle it is? Was it a new/fully charged battery? If so then probably blew a few main fuses, ECU, alternator and other electricals.
Sep 15, 2015 | Cars & Trucks
I have a 1991 ford festiva i changed my radio and now my shifter and my dash lits dont work are they wired in with the factery radio
Hi, the factory radio uses the illumination wire, but the aftermarket radio does not. You have to make sure that wire is taped off so it doesn't short the illumination circuit. Check your tail lights fuse. If it's blown, pull the head unit and disconnect/tape off the illumination wire (blue with a white stripe) from the factory harness. Then put in a fresh fuse. If you have more questions, please specify the model of the head unit.
1991 Ford Festiva Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Red/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/White
Left Front Speaker Positive Wire (+): Blue/Red
Left Front Speaker Negative Wire (-): Blue/Yellow
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Blue/White
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Nov 21, 2011 | Car Audio & Video
I changed the battery and negative treminal for my 1995 ford escort and as soon as I hooked up the battery it blew the 100 amp main fuse under the hood. I replaced the 100 amp fuse and hooked the battery...
At a guess, I'd say that you have got the new battery in back to front. This means that you are hooking the earth wires to the Positive side of the battery.
Mar 24, 2011 | 1995 Ford Escort
If van is not driven for few weeks it would not start and the battery be drained completely, jump starting it still did not help but caused mufler to blew.
to check for a parasitic drain, you will need a multimeter. with battery fully charged, remove negative cable from battery. set meter to 300mA and put negative lead on the battery's negative post. put positive lead on vehicle's negative cable and check meter reading. usually, there's an initial draw for a short time (1 or 2 seconds) for the vehicle'ssecurity system, relays, etc. after that, it should only pull 30-40 mA or so, for the digital clock, radio settings, etc. if you're seeing higher numbers, try removing the main fuses (under hood fuse box) one-by-one to see where the problem is. it's also possible that a diode has gone bad in your alternator, which will draw current when the vehicle isn't running. you can check this by disconnecting the alternator's electrical connector to see if you notice a difference on the meter.
Feb 05, 2010 | 1996 GMC Savana
Blown fuse
I suspect you toasted the diodes in the alt...how did you test it ?
Jun 16, 2009 | 2001 Isuzu Rodeo
Keep blowing fuse under hood when i put power wire in to amp
disconnect the negative battery terminal, replace the fuse with all the wires hooked up to the amp and reconnect the battery terminal, that way the initial surge of power goes through the negative terminal and not your inline fuse. That should solve your problem.
Mar 29, 2009 | Pioneer GM-5200T Car Audio Amplifier
I changed existing radio and have lost lighting to instument pane
U most likely blew a fuse, replace it, if the fuse goes again check the wiring to the radio refer to this wiring chart for color difinitions of radio wiring.
1988 Ford F150 Truck Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Dec 28, 2008 | 1988 Ford F 150
Possible electrical problems.
I would suggest that you check to see if the battery is connected properly---correct polarity!
If connected wrong, main fuse will blow. Lights come on because power is routed through the frame (ground) briefly.
Hope this helps.
Dec 23, 2008 | 2003 Mazda Protege
Alpine CDA-9855 CD Player Logo
229 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
