Question about Yahoo Messenger
TYPED A LETTER, SAVED IT AS A DRAFT AND IT NEVER WENT INTO THAT FILE. LOOKED EVERYWHERE, IT'S JUST GONE...MESSAGE SAID I SHOULD MENTION ERROR CODE 4 TO CUSTOMER SERVICE. IT WAS TITLED JUST GOING FOR IT. CAN YOU BE OF ANY HELP? CHERYL
    Problem Solver:
  • 17 Answers
Project 2010 - Unable to open file error
This is vital point which can be consider as workaround:
v Go to the document library in which project files resides
v Hover your mouse to any project file and select 'edit in Microsoft Office Project'
v It will give you a pop up by selecting the 'SharePoint drafts' option
v Click ok / you can do a check out also by selecting the 'SharePoint draft' option
v Now the document is in check out condition so go to the SharePoint drafts location on your machine (Location: \My Documents\SharePoint drafts)
v Open the document by means of draft location, do the changes and save it.
v Go back to the SharePoint site and check in the document.
v Changes will be successfully saved without any problems
Try to install this app Recovery Toolbox for Project
http://www.project.recoverytoolbox.com/
Here's one thread like yours. It could be useful for your, read http://www.filerepairforum.com/forum/microsoft/microsoft-aa/project/625-project-error-"an-import-error-occurred"
Dec 03, 2014 | Microsoft Office Project Standard 2007 -...
I have a samsung tablet and can't find the drafts folder. On the net it says to right click the inbox folder, how do you right click, there is no mouse
I'm having the same problem - I've added an account using the app (not gmail.. it's actually hotmail as one can add any email account) and when I saved the message I now see there is no draft folder to access that I can see.I also went to hotmail's web email and can't find the saved email there either. I've searched the entire tablet but cant find where it might have been saved to.
Apr 30, 2011 | Samsung Galaxy Tab Tablet PC
My GPS says " no detailed maps found that support routing. The Nuvi cannot be used without them." Tried resetting and no change
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 10, 2010 | Garmin nuvi 205W GPS Receiver
I have a Garmin Nuvi 250, when I start the unit it displays "no detailed maps found that support routing". I have checked the drive and it has over 1.3 Gb used. I used the unit last weekend but it doesn't...
To retrieve unlock codes you need to have registered your satnav. If you haven't already done so connect your satnav to the computer. Go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your Garmin product. Follow the prompts. You'll have to create a username and password. Write them down and keep them safe as you'll need them again anytime you need to update your maps.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
Maps not found
If the maps are locked you'll need a garmin account. If you don't have one already go to www.garmin.com Click on my garmin and then on register your garmin device. Note you'll have to create a username and password. Write them down and keep them safe. You'll need them anytime you update your satnav.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 08, 2010 | Garmin nuvi 260W GPS Receiver
I get the error no detailed maps found that support routing. Hwow Do I fix this?
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device in the botton paragraph
  1. Go to www.garmin.com and log into MyGarmin. If you don't have a MyGarmin account you'll need to register your satnav to get one. To register click on MyGarmin and then on Register your garmin product. Follow the prompts.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 06, 2010 | Garmin nuvi 260W GPS Receiver
I wrote the long message and wanted to send it later. Later I could not find my written mesage to send email. I did not find outbox nor Draft symbol in the screen. How should I get my written message back
It should have been auto saved in the drafts folder. If it is not in the drafts folder, It is most likely gone. Outlook uses word as an editor and word will auto save every so often. It will place an .asd file in your temp folder. Your temp folder location will depend on your Windows version. I'm not talking about windows/temp. It is most likely under Documents and Settings\(your user name)\Local Settings\temp. The Local Settings folder is hidden so you must set your settings so that you can view hidden files and folders.
I suggest either making sure you save your message to draft every so often as you write it .. OR a better solution is to use Word. Word will auto save every so often and the document can be recovered.
How auto save works
How to view your Local Settings files/folders
hopefully you can find the saved file there.
Feb 26, 2010 | Microsoft Office Outlook 2007: Windows
How do you get a signature on the lg neon
I have gone through every setting, every where on my phone and i cannot find out how to make a permanent signature! But everywhere ive gone to search for the answer says that the only way to really make a "signature" is to save a draft of it and then go to the draft everytime you want to make a message. Its quite difficult especuially if you are in a hurry, but it is the only way for now.
Dec 02, 2009 | LG Neon GT365 Cell Phone
IN THE MIDDLE OF A LONG TEXT MESSAGE.....and...RESTART
I have the same problem on mine. I'm sure its not a key stroke, because I get the same thing in portrait view, and I've also had it reset on me when I was renaming pictures. Also, I let it sit on the composing message screen for a while, and then tried to just type a letter and that set it off as well.
Aug 11, 2009 | Pantech Matrix Cell Phone
Yahoo Messenger Logo
24 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
