Question about Vacuums
Juki sewing machine (model TL-98E) motor (YDK model YM-63D-4) overheats. Where can I find a replacement?
5 Suggested Answers
  • 1739 Answers
SOURCE: where can I get a
Not sure if this is the complete manual but only site where I could find it available for free:
http://www.free-service-manuals.com/Sewing_Machines/Juki_DDL_227_Basic_Repairs_&_Adjustments_L98742/
Click on Download/Visit to receive the manual in zip format.
Posted on Mar 27, 2011
  • 586 Answers
SOURCE: I have a acquried a
Hello there,
Theres a number of causes of such problems. You will simply just have to run a check on some of the components below:
If it is the upper thread that is breaking, check Rethread your machine. An incorrectly threaded machine can cause thread to break.
Decrease the tension on your machine. The tension may be too tight for your thread.
Reposition the spool of thread on the spindle. You know that little nick in the edge of a spool that's used to hold the loose end of the thread? Your thread may be catching on this nick as you sew. Place your spool so that this nick rests against the bottom of the spindle.
Reinsert your needle. Make sure it goes all the way into the holder and that it's positioned correctly, usually with the flat side away from the bobbin, but consult your machine's manual to be sure.
Change your needle. Your needle may be bent or dull. The eye of your needle may have a nick in it that's cutting the thread as you sew. Or the eye of your needle may be too small for your thread, in which case, change to a larger needle. And make sure your needle is appropriate for the weight and type of your fabric.
Change your thread. Your thread may be weak. Or your thread may be fuzzy and irregular, causing it to catch in the eye of your needle as you sew. Cheap thread tends to be weak and fuzzy, so make sure to use a quality, brand name thread. And if you've been sewing with an older cotton thread, which can dry out and become brittle with age, try a newer thread.
Check your presser foot for damage to the needle hole.A burr in your presser foot's needle hole may be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
Also, There may be a burr in one of your thread guides, in which case, you may need to have your machine professionally serviced to have the part replaced.
If your lower thread is breaking: Reinsert your bobbin. Your bobbin may not be seated properly in its case.
Rethread your bobbin. Your bobbin may be threaded incorrectly or the thread may be tangled.
Remove some of the thread from your bobbin. If your bobbin is very full (if it's hard to insert into the case, it's too full), this may be keeping your bobbin from turning smoothly.
Rewind your bobbin thread. If your bobbin thread is wound unevenly, this may be keeping your bobbin from turning smoothly.
Try a new bobbin. There could be a nick along the edge of your bobbin spool that's catching your thread as you sew.
Clean the lint from your bobbin case.Lint in your bobbin case could be keeping your bobbin from working properly.
Check the needle hole in your throat plate for rough spots. A burr in the needle hole of your throat plate (usually caused by the needle hitting the throat plate) could be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
Hope this helped. Goodluck Elect_Comp
Posted on Aug 31, 2011
small6363
  • 18411 Answers
SOURCE: Dyson DC 24 YDK motor is toast. What to do?
click this link for full instruction how to replace the motor on DC24
http://dysonmedic.co.uk/how-to-replace-brush-bar-motor-dyson-dc24/
Posted on Oct 31, 2012
small6363
  • 18411 Answers
SOURCE: How can I replace the carbon brushes on the ydk motor of a Dyson DC 05?
have you taken the motor out yet
Posted on Nov 07, 2012
Hi there. i am looking for the manual for the juki HZL F300. I lost mine and cant figure out how to get a zigzag stretch stitch to work
I could only find this, but there may be others.
Details: Juki HZL-F300 Sewing Machine Instruction Manual - Photocopied Version
http://www.sewingpartsonline.com/juki-hzl-f300-manual.aspx
May 27, 2011 | Vacuums
Dyson went very slow and black smoke came out and it started smelling and stopped worked.
You need a new motor. It is a standard Dyson YDK motor fitted to your machine. In the UK, this will cost you about £65-£80 to have repaired.
Jan 27, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do i fit new carbon brushers to dyson dc14
It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
Also, be sure you change the filters; one of which is washable.
Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
The repair shop man says that the motor needs to be replaced, but will a YM-61A model work (has same volts, Hz & amps)? I have also found a new model #5186 motor but it's amps are 1.0 (not 1.2 like...
Yes the 1.0 motor will work. It won't be quite as powerful. But it will work. You probably will not even see the difference in the power. But yes the motor will work
Sep 20, 2010 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
We have a dyson dc 07 animal the machine was working fine then switched off after returning to the machine minutes later it wouldnt switch on, i removed on off switch cover and used a short piece of wire...
It could be the motor. I'm having to replace the brushes on my DC 05. It appears that you can only get brushes for the YDK motors in the DYSON, not the Panasonic motor. Which might be saying something about the YDK motors. What happens is that the carbon brushes wear down which is normal. However, the contact wire from the brush to its connector is set so that when the brush wears down, the wire is short enough to stop the spring etc from damaging the commutator. The end result is that you get an intermittent operation of the motor before it finally dies.
I believe all the DYSONs come with the option of both motors and you cannot really tell which motor you have until you take the thing to bits. You also cannot change motors without changing various other parts on the hoover. On my DC 05 the writing on the YDK motor tells you which one it is.
This website www. tasweb.org ,select the DC 05 option and scroll down tells you how to take the thing to bits. A search on google etc for your DC 07 may give similar results. Best of luck!
Jun 20, 2009 | Dyson DC05 Cylinder Bagless Canister...
Unable to find a panasonic replacement motor for dyson dc07 vac.
You can convert it to the YDK one if you get the YDK motor housing as well.
Mar 18, 2009 | Dyson DC07 All Floors Bagless Upright...
Vacuums Logo
127 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
