Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
Broken Gas Line
Looking for the part number to order a gas line for a 125L model. This item has two lines coming out of the fuel tank with a rubber groumit and pick up tube. Thanks for your time..
  • Anonymous May 03, 2009
    my 125l (2yr old) had same problem today. it would run fine for 1 to 3 minutes and then die. i drain the tank and fill with fresh gas/oil-no good. next i replaced plug better running but same end results. then i redid gas/oil with fresh gas and oil - still no luck.
    i then went on line and found the suggestion of fuel line and i already was thinking dirt in line so i took it part and behold a crack in one of the lines. i will go monday to a repair shop i know and see i can get one. hopefully this will solve the problem thanks
    President:
  • Husqvarna Master
  • 1,388 Answers
Fuel line is sold at many mower shops and general fixit shops by the inside (id) and outside diameter and by the length that you need. Just take the trimmer to the shop with you and they should measure the line for you. Good Luck enjoy
Posted on Dec 22, 2008
  • 50 Answers
You can obtain a length of gas line locally. Just take the broken piece to any store that services trimmers and chain saws. They will be able to match it.
Posted on Dec 07, 2008
How to repair fuel line on craftsman chain saw model number 358.360260 16 inch bar . how to do it .
Fuel lines are generally fixed by replacement of the fuel line because the rubber it is made of deteriorates from age and alcohol contained in gas. Before you begin, make a mental note or take a picture of how the fuel line runs from the tank to the carburetor so you will be able to put the replacement in the same position.
On most chainsaws you need to take some wire, make a u-shaped end, which will be used to grab the fuel filter in the fuel tank. Drain the fuel in the tank. Disconnect the fuel line from the carburetor. Generally there are two lines on the carburetor, one for fuel, the other line creates suction used to pump fuel and is connected to the motor, not the fuel tank . Just disconnect the fuel line, it is usually on the side of the carburetor and will leak gas when disconnected. Once this is done, using the wire, gently grab and pull the filter towards the filler opening and using needle nose pliers grab the fuel line above the filter and pull. The problem you may have, is if the fuel line is in bad shape it will break, But once you have the filter off the fuel line, the fuel line can be pulled out from either the inside of the tank or from where it comes out of the tank and goes to the carburetor. Once it is removed you are ready to put the new fuel line in.
It is best to put the fuel filter on the fuel line next. It easier than trying to put it on inside of fuel tank going out. Spray some WD40 or equivalent, on the outside of the gas line, to help the line squeeze through the whole in the back of the tank, which it will have the go through. From the outside of the tank, where the fuel line comes out, fish some wire inside the tank and put the fuel line on the end of it, making sure not to pierce or damage the fuel line. If needed a piece of black tape will hold the wire better and help fit the line through outside hole. Once the fuel line is on the wire, pull it through carefully out the other side of the tank. It is best to use your fingers to pull the line through the outside hole, it makes it less likely the line will get torn or overstretched as line goes through the hole because of the extra rubber used on the line to seal the tank from inside and outside. Once the line is pulled through and seated, run the other end to the carburetor and you are done.
Oct 01, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My Husqvarna 24C fuel pipe in the fuel tank has perished and broken can I replace it and if so how?
Fuel lines are a push/pull fit, the fuel line has 2 flanges, one should sit either side of the fuel tank. I will send you a link to the parts manual.
May 31, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
What Is The Quick Temporary Way to Fix Gas Line Leak?
If its rubber and its a low psi return line then you can fix it with fuel injection rubber hose and clamps. If its a pressure line it will need a fuel line repair kit If the tank has to be removed your looking @ at least 2.0 hours pluse parts. Fuel tank and or fuel sender assy or a line repair
www.xcardiag.com
Apr 12, 2012 | Cars & Trucks
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
Does the black gas line onmy weedeater connect to the (fuel filter?) in the gas tank?
Yes the fuel line on the 125l is an assembly that the fuel filter is attached to. If it is not it may still run but you are not filtering your fuel and any impurities could damage your carb and possibly your cylinder wall.
Jun 09, 2010 | Husqvarna 28cc Gas Line Trimmer
Hi, i purchased a 4 cycle craftsman weed trimmer about 2002 and the gas lines going into the gas tank have broken off just above the tank. The model number plate has been destroyed and the only model...
The trimmer is made by Poulan for Sears. If you have a good shop in your area, you can get fuel line from them. I use a tygon fuel line that comes in a 50 ft roll. It is a lot cheaper and easier than waiting for parts to come in.
Take a piece to your local mower shop, have them match it up. You may need about 1 ft or a little more, plus get you a new fuel filter while you are there.
Feb 25, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel lines inside of tank fell off
This is the typical fuel line routing2.gif on many models: One line ( the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
248 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
