Question about Compaq Presario Notebook
Will not turn on or charge. It came on once and then went into hybernation within a minute. The power from the cord is 18.8vdc. The charging LED is not lit when plugged in. The charging LED flashes yellow when to try to turn power on. If it needs a battery how do you remove it?
    Problem Solver:
  • 10 Answers
Sounds like battery is naff,normally to remove battery from any laptop their is a slide button underneath or on the side,or on older models a slide cover which you slide down a bit then use the cover to pull the battery out.youll find it.
Posted on Dec 07, 2008
Hi there. Last night I switched on my Asus A3Ac laptop. Its turned on, and after few minutes it went into hybernate, I pressed all the keys but there is no response. So I forcefully shutdown the laptop....
Try removing the battery and connecting your charger. Press power button for some seconds. Disconnect the charger, reinsert the battery and switch back on. Should work now. Else your power supply is faulty.
Nov 21, 2014 | Computers & Internet
1525 wont come out of hybernation and the battery wont hold a charge either. Ive tried removing the battery, pushin the power button, lettin it die n try bootin up. Its stuck in hybernation, help me...
Hybernation is one of the worst idea's that microsoft has come out with, it usually ends up corrupting windows making it useless. The only option is a fresh install of windows, and I recommend the hybernation feature be disabled. The battery may start to charge when the new operational windows is running, if not! replacement needed.
Apr 14, 2012 | Dell Computers & Internet
Computer suddenly went into hybernation. Could not restart computer.
Remove battery and lower plug keep the power button pressed for about 1 minute to drain any charge left then only pluck in the mains power and try switching on computer Update please if that didn't work
Jul 11, 2011 | Aspire Computers & Internet
My acer aspire one pav70 went into hibernating mode . how do i get it out of hibernation
It could have gone into hybernation for more than one reason.
Either it has been programmed to or the battery is low. Either way pressing the power button momentarily will get it out, if the power supply is plugged in or the battery is charged.
To remove the hybernation option, right hand mouse click on the battery icone on the desktop and change you power settings.
Hope that helps.
Nov 28, 2010 | Acer Aspire One Netbook
My laptop is not switching to AC mode even when plugged into Ac Power outlet. I work on battery mode and after full battery drain, the laptop goes into hybernation...once into hybernation it starts...
1. You may possibly have a faulty power supply adapter. Contact the manufacturer and see if there are any call backs on the power adapter for you laptop unit
2. you may also have a damaged connector at the laptop connection. This will require repair by a technician.
Aug 03, 2010 | Computers & Internet
I must have hit a wrong button and my presario 2100 went in to hybernation. I have tried everything to get it on and it will not go on now. I even unplugged the power cord for a while and it still wouldn't...
press F8 on bootup and look for an option asking to "delete the hybernation data and proceed with normal bootup". if not found then select <last good bootup" if that also fails then boot in safe mode. On bootup, go to Start->All Progs->Accessories->Sys Tools->Restore. And restore to a previous date when your PC was working absolutely fine.
Aug 22, 2009 | Computers & Internet
Will not turn on
Probably needs a new battery, simple to remove, there should be a little slider on the bottom of the laptop that u flick accross and the batery will come straight out :D
Dec 06, 2008 | Compaq Presario Notebook
Random Hibernation
this sounds like power settings options.
what i can suggest now is that......................
go to the Power Options in the Control Panel and do the following.
  • first uncheck the hibernate option on the hibernate tab
  • use your computer and see if the problem re-appears, go to the control panel and on the power option, select Never to all options when using battery or ac power.
cheers...............
Oct 24, 2007 | Sony VAIO VGN-N130G/W Notebook
Compaq Presario Notebook Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
