Question about Simplicity Liberty SA1600 Mechanical Sewing Machine
My top stitch comes out normal, but the bottom stitch is all messy & bunched up. I cant get anything to work
  • Bbbrusherd Dec 16, 2008
    I have a new machine \. And when i sew I get little nests on the bottom,when i sew a curve. My top stitch is fine.
    Bridget
    Problem Solver:
  • 8 Answers
Adjust the tension in the bobbing thread & oil the machine real good
Posted on Dec 06, 2008
How hat do to adjust the tension on my Singer 3201 - the under thread is real loose
If the bottom stitches are messy it usually means the top thread isn't threaded correctly.
May 10, 2014 | Singer Sewing Machines
Sewing machine not working in reverse
try a new needle
try a different thread top and bobbin
try adjusting the top thread tension one number or letter at a time
higher sewing on a scrap piece of paper till the stitches look
normal
make sure the top thread does not come off the thread take up lever
Jan 11, 2013 | Sewing Machines
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
make sure the thread has not come off the thread take up lever
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
How do you stop stitches bunching up on a Singer Symphonie?
also try changing the top tension
clean under the needle plate & in the bobbin area for lint or loose threads
Apr 21, 2012 | Singer Sewing Machines
I am trying to sew a boat canvas top with sunbrella canvas. my top stitch is beautiful but the bottom stitch is loose and messy. Is this just a tension adjustment and if so what should I be adjusting?
Try adjusting the top tension dial to tighten up the loose stitching on the underside. Generally if you have loose threads underneath, its the top tension and visa versa.
However, if you are using a thread heavier than normal sewing thread through the needle and bobbin (which you probably need for this canvas) then the machine may struggle. I've sewed vinyl seat covers and gave up with my domestic machine and purchased a second hand industrial Singer machine 20U to cope with this heavier weight textile. Generally for anything heavier than upholstery fabric a domestic machine may not be strong enough.
May 04, 2011 | Husqvarna Sewing Machines
The top thread is looking good, the bottom stitch is bunching up
re-thread the top, when the top looks good but the bottom is bad it is the top thread
Oct 16, 2009 | Necchi Sewing Machines
Sewing machine
The top tension pulls the top thread up. The bobbin tension pulls the bottom thread down. A balanced tension is an an even knot between the stitches.
If the thread is messy on the bottom, the top tension is non-existent or is too low. The top thread tension dial should be on 4 or 5. Pull the thread out and re-thread the machine with the presser foot up. If it is still messy, perhaps there is a burr on the bobbin case snagging the thread.
Jun 19, 2009 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Topand bottom stitches are not even
Could be a tension issue.
Try this to see if it helps:
Remove top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start the top tension set at the midway point and then adjust.
Check that the bobbin is threaded and installed correctly.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Apr 22, 2017 | Singer 7436 - INGENUITY
Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Mar 25, 2008 | Bernina Activa 130
Won't sew
you have tread in the bottom of it. and needs a cleaning. check the tension, most set on 3
Dec 15, 2007 | Kenmore 12102
Simplicity Liberty SA1600 Mechanical Sewing Machine Logo
105 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
