Question about Philips GoGear HDD6330 MP3 Player
Wont turn on?
Do the same as when it freezes when turned on, mine would not turn on, or charge or anything. press power and volume up and it started working
  • jewlz Mar 14, 2008
    will not turn on even with it pluggen in. nothing shows up on screen and it worked fine all day! whats the problem and how can i fix it? please help
  • mnkymanslim Mar 15, 2008
    my battery is not working it says it is charging but if it is not pluged in it doesn't turn on when connected to pc it says battery is 100% charged it is also connected to the ac at the same as computer or it wont work then either
    i tried reseting on the computer and the quick restart w/ power and volume up doesn't work any other suggestions.
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
Why wont my tablet lock and the volume keys won't work?
in settings, try to put the "sleep" timer to 2 minutes, and see if it actually locks (or sleeps:turn off the screen)... also with mine sometimes the "capture screeen" feature works (more donts than do's!) perhaps very poor quality from the buttons.
clean all the apps running, and start with a full fresh boot (turn off by holding the power button 10 secs or more, then conecting to the charging usb, press again the power button), the volume also can be set via software, again in settings.
Aug 24, 2014 | Insignia - Flex 10.1" Tablet with 16GB...
Tablet will not charge or turn on
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. if this doesn't work your charging port may be lossened or damaged, have a technician check it.
Mar 05, 2014 | RCA Tablets & eReaders
RCA 7 inch table says no command
Mar 03, 2014 | RCA 7 DUAL TABLET DVD SYSTEM
Wont finish its loading process
Feb 06, 2014 | RCA Tablets & eReaders
Samsung galaxy stellar keeps freezing
I fixed mine!!! Okay. This is what you do. Make sure your phone is off and to turn it back on press Volume up and the Power on button at the same time until it says something like rebooting system at the very left top in blue. A menu will come up. Using the volume up and down, select the reboot option. It will wipe everything out, but as long as you are set up with google, you wont lose your contacts. There will be a confirmation question with a bunch of no's and a yes. Select yes using the power button. In yellow writing at the very bottom it should say that your phone has been rebooted. It will then turn on by it's self and you will have to re- set up your phone just like you had to the day you first got it. Sorry I don't remember everything word for word, but I just got off the phone with a representative and that's what he told me to do. It worked!! If it happens again though, contact your provider and tell them. They will replace your phone if it's still under warranty :)
Oct 28, 2012 | Samsung Galaxy S 4G Cell Phone
My Htc Chacha's lcd light keeps flickering on & off it wont charge what does that mean ?
Sindia, this sound me software problem, when your device has a software problem it wont charge or start at all normally, so try to hard reset but this will delete all data for hard reset follow the instruction :
1. Switch off device;
2. After 3 min, Press and hold volume down button and power on button once it shows 3 android images appear leave the buttons and press volume down to select a clear storage, and then press power and then press volume up to start the factory reset. after this process your device wil reboot and start normally. now your device is ready to use. Best of Luck.for further help post comments.
Source :
http://www.hard-reset.com/htc-chacha-hard-reset.html
Jul 13, 2012 | HTC Chacha Smartphone
Nintendo dsi screens keep freezing and will not turn off
what ever you do dont listen to him there is a solution mine was stuck white screen and would not turn off and i was so close to doing what he said but now here is the solution
Step one:unplug dsi (if it is charging)
step two:close the dsi
step three:once it is closed turn volume down all the way witout opening
step four:set the dsi in front of a fan vent or someplace it will get a breeze
step five:open the dsi and hold power switch for like 6 to 10 seconds
(even when it turns off keep holding it for a couple more seconds)
now you an plug it back in and turn it on and VAWALä
hope this helped:)
Apr 12, 2009 | Nintendo DSi White Console
Freezing on start up
hi return this cause is defect i know i have one !!!
Jan 02, 2009 | Philips GOGEAR SA6045 MP3 Player
Archos 504
I had a similar problem remove the battery and push the gold coloured reset button. It worked on mine, You don't lose any info doing this. I got the advice from the Archos support phone number CC
Aug 19, 2007 | Archos 504 500870 Digital Media Player
Philips GoGear HDD6330 MP3 Player Logo
163 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
