Question about Watches
I CANT FIND MY WATCH COULD U HELP LIMITED SWI EDITION AUTOMATIC 25 JEWELS STAINLESS STEEL SAPPHIRE CRYSTAL 10ATM, WANT TO KNOW THE VALUE PLEASE
ItsRixTime
SOURCE: how do change a battery of a watch?
If you do not have the proper tools,(proper tools are recommended) and depending on the type of backing, this may help you :
  1. Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal.
  2. Get a kitchen knife with a rigid blade. It doesn't have to be razor sharp, it only needs to be inflexible. You can also use a small fine screwdriver.
  3. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  4. Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  5. Locate your battery(Small round disc type) remove and check the numbers on it. Go to most any local dept. stores (Wal Mart, Target, Radio Shack, etc.) and purchase same.
  6. Install battery with numbers up.
  7. Place cover over watch, and snap back into place.
Hope this helps. If not, please let me know and I will get back to you.
Posted on Feb 07, 2008
escapement
  • 2334 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
  • 19 Answers
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
Posted on May 24, 2010
mcdevito75
  • 1970 Answers
SOURCE: i have a continental 17 jewels watch and it looks
mcdevito75 here, You can try online at Continental watch.com However the numbers on the movement itself count the most, numbers on the watch face and back cover help. HINT!! -- If your Continental Watch has thick hands It"s most likely before 1965, if your watch has thin hands it"s most likely after 1965. Best bet, look for a small watch repair shop in your area, they can guide you too a shop that will know if they don"t. Also, you can check with any Antique shops in your area too.
Posted on Jul 03, 2010
  • 66 Answers
SOURCE: umm..mine is called.."FOSSIL 10 ATM" there's
10 ATM means that the watch is water resistant to 10 atmosphere's of pressure.
Long story short, yes you can swim with it. Yes, you can shower with it too.
Posted on Aug 02, 2010
I have a folio 21 jewels limited addition watch. I dont know how to wiend it. And I need to know what its worth.
I have no idea of the value.
You say that it's self-winding, but that you don't know how to wind it? Just wear it - the movement of the arm and wrist winds the watch. If the watch is fully wound down then it may take a while for the watch to have enough power to restart. Some automatics will allow you to wind the watch in the normal way with the crown.
Oct 21, 2017 | Black Watches
Tip
Watch glossary: G, H, I, J, K.
GENEVA SEAL, see poinçon de Geneve.
GLASS, see also crystal
Thin plate of glass or transparent synthetic material, for protecting the dial of the watch.
GLUCYDUR
Bronze and beryllium alloy used for high-quality balances. This alloy assures high elasticity and hardness values; it is non-magnetic, rustproof and has a very reduced dilatation coefficient, which makes the balance very stable and assures high accuracy of the movement.
GMT
Abbreviation for Greenwich Mean Time. As a feature of watches, it means that two or more time zones are displayed. In this case, the second time may be read from a hand making a full rotation in a 24-hour ring (thereby also indicating whether it is a.m. or p.m. in that zone).
GONG
Harmonic flattened bell in a steel alloy, generally positioned along the circumference of the movement and struck by hammers to indicate time by sounds. Size and thickness determine the resulting note and tone. In watches provided with minute-repeaters, there are often two gongs and the hammers strike one note to indicate hours, both notes together to indicate quarters and the other note for the remaining minutes. In more complex models, equipped also with en-passant sonnerie devices, there may be up to four gongs producing different notes and playing even simple melodies (such as the chime of London's Big Ben).
GUILLOCHE
Decoration of dials, rotors or case parts consisting of patterns made by hand or engine-turned. By the thin pattern of the resulting engravings - consisting of crossing or interlaced lines - it is possible to realize even complex drawings. Dials and rotors decorated in this way are generally in gold or in solid silver.
HAMMER
Steel or brass element used in movements provided with a repeater or alarm sonnerie. It strikes a gong or bell (s).
HAND
Indicator for the analogue visualization of hours, minutes and seconds as well as other functions. Normally made of brass (rhodium-plated, gilded or treated otherwise), but also steel or gold. Hands are available in different shapes and take part in the aesthetic result of the whole watch.
HARDLEX CRYSTAL
is Seiko's trademarked name for a hardened mineral crystal.
HEART-PIECE
Heart-shaped corn, generally used to realign the hands of chronograph counters.
HELIUM VALVE
Valve inserted in the case of some professional diving watches to discharge the helium contained in the air mixture inhaled by divers.
HEXALITE
An artificial glass made of a plastic resin. Back in the 1960's, many watches used either mineral glass or acrylic crystals. These are not difficult to scratch, but very inexpensive to replace. Now though, most all luxury watches use the highly scratch resistant synthetic sapphire crystals, there are some styles/brands that use the Hesalite (a name brand of fine acrylic crystal). The reason for this is directly related to the watch's certification for use in space or in high stress/impact situations. While sapphire crystals are less prone to scratching, they can be shattered. When shattered, they break into tiny fragments that would be hazardous in some environments. So the Hesalite crystal is maintained on some specific models as a safety feature.
HUNTER CALIBER
A caliber characterized by the seconds hand fitted on an axis perpendicular to the one of the winding stem.
INCABLOC, see shockproof.
JEWEL
Precious stone used in movements as a bearing surface. Generally speaking, the steel pivots of wheels in movements turn inside synthetic jewels (mostly rubies) lubricated with a drop of oil. The jewel's hardness reduces wear to a minimum even over long periods of time (50 to 100 years). The quality of watches is determined mainly by the shape and finishing of jewels rather than by their number (the most refined jewels have rounded holes and walls to greatly reduce the contact between pivot and stone).
JUMPING HOUR
Feature concerning the digital display of time in a window. The indication changes almost instantaneously at every hour.
KINETIC
Refers to the Seiko line of Kinetic watches. This innovative technology has a quartz movement that does not use a battery. Movement of the wrist charges a very efficient capacitor which powers the quartz movement. Once the capacitor is fully charged, men's models will store energy for 7-14 days without being worn. Ladies models store energy for 3-7 days. Of course, if the watch is worn every day the capacitor is continually recharged. The watch alerts the owner to a low capacitor charge when the seconds hand starts to move in two second intervals. Some of Seiko's Kinetic Watches have See-Thru CaseBacks, that use a clear, Hardlex crystal watch back to enable the wearer to view the kinetic movement.
KINETIC AUTO RELAY
A Seiko Kinetic Auto Relay watch is powered by human movement, however when it senses inactivity for three days, it puts itself into suspended animation to conserve energy. It can be re-activated with a few shakes of the wrist. It automatically resets itself to the exact time after to up to four years of dormancy.
on Jan 11, 2010 | Watches
Value for 28116BK
about $100.
Lucien Piccard is a brand with distant Swiss heritage, which now has the same address as Invicta, SWI group, Stuhrling/Akribos and World of Watches. Asian manufacture and always a deep "discount" from list price. This isn't to say that they don't have some great looking watches, only intended as a bit of background to the company.
Mar 20, 2017 | Lucien Piccard Watches
Which is a better gift for my boyfriend? Please do help. :)
the swiss watch. also a new fishing rod and a case of beer
Apr 06, 2017 | Timex Indiglo Watches
The glass face of this watch has cracked-please advise how to get it replaced and estimated cost--thnak you located eastern massachusetts, usa
Good luck finding a crystal, took me 2 years to find one for my bedat 384 women's watch! Finally took a shot and got one on eBay by luck. I haven't had mine fixed yet but hopefully soon. The crystal alone was 100$ and I have no clue what they will charge me to put in the new crystal. I was given a quote of 200$ over 2 years ago when it first happened.
Aug 25, 2011 | Bedat & Co. Automatic No. 7 Swiss...
I bought a Croton watch style is Croton Automatic limited edition 0202/1000, 35 jewels, I'm having a problem with it self winding, the mechanism in the back seems to be jammed, it will not spin easily...
It sounds like you have be sold a lemon!
If you have recently bought it and you have a proof of purchase (and it is still within the warranty period) then you should return it for repair/replacement.
Apr 01, 2011 | Croton Watches
I Have a Ricoh Watch. I believe it to be the Ricoh Automatic Watch released as a pack when they released their first automatic camera (a camera specialist friend gave it to me as a gift). However, I cant...
I dont exactly understand what your problem is with your watch, but if you just do a GOOGLE image search using RICOH WATCH in the search., it will pull up a ton of images and you can find your watch that way.
I dont know if that is the answer to your question, but it will work.
Best regards.
Aug 23, 2010 | Watches
Cant restart my cartier roadster chronograph. havent been using it for a couple of days and the movement wont start. please help
If the watch is quartz its a cell replacement,use a watchmaker on a watch of this value.If its an automatic watch then you may be looking at a repair/service.A watch of this quality needs regular servicing at 4 years or so as lubrication drys.For work of this nature you will need a specialist watchmaker try www.rolexrepairs.co.uk
Aug 16, 2010 | Cartier Roadster Chronograph White Dial...
Umm..mine is called.."FOSSIL 10 ATM" there's also something written at the back saying, "stainless steel caseback, next a water symbol, then 10ATM..I'm just wondering what this means?? can I wear this...
Aug 02, 2010 | Watches
Watches Logo
66 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
