Question about Sony KV-27V55 27" TV
KV27TS25-Digital Ready? I have a Sony Model #KV27-TS25. Is this already set for digital or will I need a converter box come 2009?
5 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: digital signal
Hi.
You havent stated your make or model of tv set ?
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 30, 2007
  • 8 Answers
SOURCE: IS MY TV DIGITAL READY
Its tuner is NTSC, which will not tune in digital stations. I didn't see a DTV tuner mentioned anywhere on the specs, so don't think it will work. I myself have one and will soon purchase a converter box with the $40 rebate from the government.
Posted on Jun 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: "Digital TV ready"
The minute I searched on your model number on philips.com, the answer appeared:
Here is the answer
Posted on Jul 17, 2008
  • 2296 Answers
SOURCE: Tuner
Yes, you will need the converter box in order to view the digital channels if you are receiving off the air signals but if you have cable or satellite TV, you might not needed. You can click here to know the specs of your TV, it has an analog tuner and not a digital.
Posted on Aug 02, 2008
tvguy171
  • 106 Answers
SOURCE: my ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
Posted on Dec 20, 2008
Do I need a convertor box or is this Digital ready?
That set has both digital and analog capabilities, so no you dont need to get a converter box.
Mar 26, 2014 | Samsung HC-R5245W 52" HDTV
Hi! just need to know if my tv is ready for digital tv i have the sony kp-57ws520. i've hooked up my antenna and i still dont get a picture thanks for any info.
Your Sony KP-57WS520 television has an analog tuner, so you may need a digital tuner or a converter box to continue to receive over-the-air programming.
If you subscribe to a cable or satellite service, your television viewing should not be affected by the June 12, 2009, cut-off date for full-power analog broadcasting. Please contact your service provider for complete information.
Go here for more info:
http://esupport.sony.com/US/perl/model-home.pl?mdl=KP57WS520&LOC=3
Jul 07, 2009 | Sony KP-57WS520 57" Rear Projection...
Does my Insignia come digital cable ready or do I need a convertor box?
Cablevision is forcing people to having to buy Digital Cable Boxes with decoders in them.. On top of what you are already paying you have to pay lets say 2- 6$ per tv for a box per month.  Cablevision is doing this and charging more.  It's really to bad.
May 06, 2009 | Insignia NS-LCD19 19 in. LCD TV
Dont have cable. i bought the analog converter, but read i don't
Digital Ready is not the same as having a digital tuner built in. Yours is probably the former and you do need a converter box: http://www.ezdigitaltv.com/HDTV_vs_HDTV-Ready.html
May 04, 2009 | Sharp LC-32SB24U 32 in. LCD TV
I don't know if my sony trinitron kv-2742 27" tv needs a box
Given the history of the aquirement, I checked the model number and there is no reference to be able to receive digital. You can buy a convertor box anytime they are available to use on the set. There is no deadline to hook it up.
Feb 15, 2009 | Sony KV-27V42 27" TV
I have a sony trinitron wega tv model number KV-32FS120 and I was wondering if it is digital ready or do I need to get a converter box
This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products.
Jan 06, 2009 | Televison & Video
Jun 10, 2008 | Sanyo DS24425 24" TV
Will it work in 2009
the answer to your question is yes but, only if you are using an areal antenna to veiw tv, you will need a converter. the change over only affects those who use an antenna and have a NTSC tuner.
if you have satelite, it is already a digital format no converter needed. the sat box is the converter
if you have cable you will not need a converter. most cable companies will still pass thru the anolog signal. but getting the digital service is not a bad thing.
Mar 24, 2008 | Televison & Video
Dtv ready?
Usually on the back of the set there will be a hookup for digital tuner. To get the converter box before Feb 2009 go to http://www.dtv2009.gov
Mar 15, 2008 | Orion STV2763 27" TV
Making Trinitron HD-compatible
Every one seems to have a problem understanding what real will happen in Feb 2009 First if you already watch TV from a cable provider you WILL NOT have a problem, Now if you have a set that picks up a signal over the air (rabbit ears or antenna) then you will be affected and will need a converter. Check www.dtvtransition.org for more details. And Finlay if you watch from a satalight receiver you will be fine
Feb 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Televison & Video Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
