Question about Sony KP-57WS500 57" Rear Projection Television
Blurry and bent screen
The picture on the screen looked bent so i cleaned the mirror and three projectors(i didnt adjust the projectors) now the whole picture is completely blurry how do i fix this problem at home?
  • tommydrury84 Dec 07, 2008
    no all i did was clean them everything is as was before
  • thielectronick
    thielectronick May 11, 2010
    are the colors (red, green, blue) mis-aligned? = convergence
    are they out of focus? = bad focus block or power/defection board
    Champion:
  • 205 Answers
When you cleaned the "projectors: you knocked them out of alignment. If you cant correct by menu, I suggest you call a service technician, should be less than an hour for qualified tech to solve the problem, Good luck
Posted on Jul 07, 2009
  • 22 Answers
It sounds like you have moved the mirror, turn it on and try to see if you can realign it. KEPP YOUR FACE OUT OF THE LIGHT PATH.
Marc Engineer
Posted on Jun 17, 2009
Picture looks 3d how do i fix
If you can access the three projector lenses you will probably find them covered in dust, this shifts the light slightly giving a blurry 3D effect on the screen. Clean the dust off with lens tissue and window cleaner or a cleaner made for glasses and this will restore your picture.
Sep 07, 2014 | Samsung HLP4663W 46" Rear Projection HDTV
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Picture is dark, appears to need either cleaning, some sort of adjustment or both.
Some projection tvs have three picture tubes called CRT, this crt system requires a little manintenence every once in awhile, lens and mirror cleaning as well as projection screen cleaning, there are other procedures that have to be ran sometimes to return the picture to a regular viewable level. With the projector type of TV, there is usually the light box , mirror and screen maintenence, these procedures should be done at least once a year and only requires a minimum of materials and time, and there are other parts and procedures that can bring the picture to normal viewing levels.
Feb 21, 2010 | Samsung Televison & Video
My big screen Rear Projection Television set is blurry.
Consider new purchase, your crts are getting old and can't reproduce same quality. High voltage is going and loosing focus. good luck
May 17, 2009 | Zenith R57W46 57" Rear Projection...
Gmc suburban heater not heating up
The #1 cause for this ailment is low coolant. Be sure the air was burged from the system so that the heater core is not airlogged. #2 check for broken or disconnected vacuum lines under the hood. The heater air cond. system is dependent upon vacuum to actuate the dampers in the airbox. Rarer: check the heater hoses for restrictions, I have seen good looking hoses delaminate internally and pinch off the coolant flow. Somewhere between #1 and #2 I should mention the thermostat. But if the thermostat is at fault the temp guage will never reach the normal range.
First, my disclaimer:
I have a much older projector, but the way they are constructed hasn't changed a lot to my knowledge.
An excess of dust can shorten the life of electronics, it's a given. But the majority of these sets are allowed to collect dust for many years of operation before any problem occurs.
I sense that you may instead be asking about cleaning the lenses and mirror. Actually, the mirror, since it faces somewhat at a downward angle in these sets tends to stay clean. the lenses however, face upwards, and do get quite dusty, causing a blurry picture, with ghostly images on the screen at their worst.
To clean the lenses on most RCA sets I've seen, the screen must be removed. Allow the set to cool and voltages to dissipate for 30 minutes before beginning this process. There should be a removable panel beneath the screen, usually retained by screws on the backside at each end. REmoving the panel will expose the screws that keep the screen in place at the bottom. With the screen removed, the lenses (there are three) will be quite obvious. I clean mine with typical glass cleaner and SOFT paper towels. PAY ATTENTION not to allow any liquid to drip into the projector below or you may disable the projector unit possibly causing damage that must be repaired. If you are successful at the lens cleaning you will have restored the picture quality to like new.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 19, 2008 | 1990 GMC Sierra
Blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Dec 10, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How to take cover off
Nov 19, 2008 | RCA D52W19 52" Rear Projection Television
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Picture get blurry on right hand side
if the convergence is also off suspect convergence ic problem
Nov 27, 2007 | Philips 43PP9202 43" Rear Projection...
The TV Picture
The most common reason I've found for picture deterioration with projection TVs is dust build-up on the mirror. Try popping off the trim around the screen and look of several screw and retaining clips and remove them. Now remove the screen - it's just a piece of plastic. Now the mirror should be in plain view. Simply clean it thoroughly with windex and newspaper (you can also clean the back of the projection screen since you have it out). Now replace the screen and see if the picture doesn't look much brighter and clearer. This should be done perhaps every six months as TV generate a lot of static which attracts dust like a magnet. If the picture is blurry after doing this, it's possible to adjust the projector beams (there are three) to better align with the position of the screen, however I'm willing to bet this won't be necessary after the cleaning procedure. It sounds complicated, but trust me, anyone can do this. If you cannot locate any retaining clips on the front, you may have to go in from the back, in which case you'll most likely have to complete remove the mirror to clean it. It's a little more involved than the frontal method, but equally effective. It's also possible that you have a bad projector. When you get the screen off, make sure that each one is lit (the red one always looks dimmer than the green/blue ones). If one is out, try tapping on it, it might just come back to life, you never know. If not, have it replaced (usually around a $200 fix). Hope this helps you, and good luck!
Feb 08, 2007 | Hitachi 50UX57B 50" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
136 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
