I'm selling my Flatron LG L196WTQ 19 inch TFT LCD Monitor to someone, but I seem to have lost the installation CD. Do they need it?
    President:
  • 1,073 Answers
No!
If drivers needed they can always been downloaded from the net.
Good luc!
Posted on Dec 06, 2008
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
HOW TO CHECK A LG FLATRON L194WT-SF MONITOR FUSE, THE REAL PROBLEM IS HOW TO REMOVE THE BACK COVER
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194W&kategoria=monitor&kat2=all
After removing all the screws and the base, I use thin flat blade screw driver to crack open the case starting at the bottom egde and work your way around, just watch out for any cables attached to the front bezel. The monitor is not made to be easily open up.
Please read my guide so you will know what to look for inside the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 15, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
My lg flatron l1953s does not power up. the power cable is not broken or cut. it sents power but my screen doesn't power up
check the connection to the pc.If the VGA connector is not connected to the pc the monitor is not power on.Better check the VGA cable connection and fix it.
Oct 04, 2010 | LG MNTR |LCD 19' 5MS L1953S-BF RT 19 inch...
Xp os i make a misstake full resolution and screen is blank plz help me lg lcd 32 inch
reboot PC in save mode and set the resolution to 640 x 480 @60Hz, reboot in normal mode and reset the resolution to the native resolution of the monitor (you need to find out what that is in the monitor owner manual).
Mar 09, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron L196WTQ-BF Monitor will not power on
Here is a link to a How To on this monitor (and similar) they offer cheap parts as well.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/comment-page-1/#comment-136
Nov 12, 2009 | Computers & Internet
The monitor get on for a second, then it goes black
sounds like a blown backlight (the TFT screen is lit from behind by thin white flourescenet type tubes,
if these become faulty then you cannot see the display output as it is no longer lit from behind
Mar 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
