Question about Whirlpool LSR6332K Top Load Washer
Washer leaks under the machine
My water lines is the house froze up and after we got most of the lines unthawed we turned on the washer and water came from under the washer. What do we do?
  • 87 Answers
Probably a cracked pump, or cracked water solenoid
Posted on Jun 09, 2007
Water leaking under washer
Chances are it's the 6 inch or so rubber "U" tube you see attached from the diverter valve to the pump. The end that goes to the pump has to slip under the metal housing and turn it about a half an inch, then use the clamps to secure it.
Feb 15, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
I just moved and the washer froze while in transport. There is a small leak which means a line froze? If not a line what could it be? Thanks
If your line is not frozen and cracked then it's the water control on the back of your washer where your main water hoses screw into the washer. Check this water control because it is plastic.
Feb 11, 2011 | Whirlpool Inglis IP4400 Washer
Have hot/cold water pipes coming outside from roofspace in house to garage for washer/dryer. Already had two bursts inside garage and machine and electrics destroyed. New machine installed after...
Insulation only slows down the transfer of heat (cold), it does not stop it. If it is below freezing and the water in any pipe is not moving, it will eventually freeze. Most major industrial supply houses like McMaster-Carr or Grainger in the US, carry pipe tracing tape. It comes in various lengths and you secure it to the pipe under the insulation, plug it in and many types have integral thermostats that keep the pipe above freezing. If you have a washing machine, you will have to consider the lines to the washer valves, both hot & cold and any other areas in the washer that may hold water like the pump and the discharge hoses.
Was this washer always outdoors?
Jan 08, 2011 | Easy Heat Water Pipe Heating Cable
Washer fills with hot water even when unplugged
The freezing messed up the fill valve. This is the part that your hoses connect to on the back of the washer. Replace it and you will be fine.
Jan 11, 2010 | Maytag PAV2300 Top Load Washer
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
Washing machine leaks after pipes froze in room
The problem is most likely the water pump and supply hoses.
If your system froze up where the washer was located then it is possible that the pump or supply lines also froze because they always have water in them.
The repair price will vary with whoever you call to fix it.
Jan 29, 2009 | LG WM1814CW Front Load Washer
Kenmore HE4T Washer Leak
there are 2 possible causes.
either
inlet valve leaking - turn water off and if water fill stops, it indicates valve leaking
valve being powered when machine off. this is very unlikely but to check, disconnect washer and see if problem stops
also, if drain is plumbed into a spigot on the sink trap, every time you empty the sink, some of the water will flow into the machine. to cure this, take the drain hose as high as possible under the sink in a swan neck
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
Water running out from under the washer
sounds like two seperate problems. firsst water running from under your machine might be a bad seal, or water could be backing up the drain line. i would guess that it is a plumbing problem because of theissue with water in the sink. have a plumber snake out the drain lines and the problem with the washer should disappear.
Jan 21, 2008 | Speed Queen AWS52NW Top Load Washer
Water leaking from under the front of the washing machine
The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Dec 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR6332K Top Load Washer Logo
77 people viewed this question
Sal De
Marvin
Marvin
jimorris77
