New thermostat not starting compressor
I just installed a new programable hunter model 44110 thermostat and the fan will start but the compressor will not
the old thermostat was a carrier model hh01ad042 the only issue i had some question on was on the old carrier unit the red wire (R) was jumped to a terminal marked with the number (4)
all other conections were normal
green = G = fan
yellow = Y = compressor
white = W = heating
Do I leave the jumper in place on the new hunter unit, remove it, or something else?
  • 85 Answers
With the jumper inplace does the compressor start? What about without? Unless you have more than one transformer you should leavethe jumper.
Posted on Dec 06, 2008
Hunter Programmable Thermostat
My Hunter Programmable Thermostate #44110. I set it for regular clock time. But in the middle of the day and night it goes to military time. When I hadn't added military time. Is it time to buy a new one. I've had it for 8 years.
Apr 15, 2015 | Hunter Fan Company 7-day programmable...
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermostat 44110
This sounds like a split system, the condensing unit outside and the evaporator coil and fan inside. You must be referring to the indoor fan, since the compressor and outdoor fan are controlled by the same contacter. The indoor fan relay contacts sounds to be welded shut, and needs to be replaced.
Aug 24, 2013 | Heating & Cooling
Not working
"G" terminal is for the fan, typically using a green wire. "C" terminal is the common, basically a ground, typically using a blue wire. Also, leave in the jumper between "RH" and "RC".
May 19, 2010 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44110 programmable thermostat not turning off ac
You may and an anolog stat and the old one was digital if so it won't work. Digital sends info to system anolog is just a set of points open or closed. Digital can carry tons of info to system like a computer. Like comparing a computer to a rock. Sorry but you need to go back to proper type stat.
Jun 30, 2009 | Heating & Cooling
Need help with wiring on Hunter 44110
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Mar 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5 + 2 thermostat #44110 Set and Save/Energy Star
i would say normal, between my family have 3 different hunter models, and they all do it.
Jul 04, 2008 | Hunter Fan Company 5/1/1 Programmable...
I have a hunter programable thermostat model number 44422 and the condenser outside will not kick on The fan is working inside but I have no cool air(air conditioning) I do not understand why the outside...
The outdoor unit has failed in some way. This is probably not the thermostats fault. You can check the breaker for the outdoor unit by turning it off and then back on. If this does not work, the problem is most commonly one of the following issues. All of which should be done by a professional because the danger of electrocution.
1) Bad Start/Run capacitor
2) Bad Compressor
3) Bad Exhaust fan motor
4) Combination of some or all of the above.
Jul 03, 2008 | Hunter Heating & Cooling
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
402 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
