Question about KEF Audio KHT 2005.2 System
KEF KHT 2005.2 SUBWOOFER
Hello I have broken one of the leads at the plug leaving the pin in the socket on the sw unit,after removing the pin, the sub is powering up ok but has lost all function and is crackeling.
After talking with a local kef dealer he advised me to exchange it through kef,(at a cost of £100) surley it is only blown circuitry that can be repaired,Any ideas?.he did say it was a common fault causing a crack on the vero board?
Over to you, and many thanks
    Scholar:
  • 101 Answers
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Posted on Jan 15, 2010
Kef htb2 subwoofer not working plug fuse ok sub fuse ok is there an internal fuse
If you have external fuse there will be none internally. Chances are you have blown the amp if power is confirmed to be getting into the unit and there is no sound.
Sep 16, 2017 | KEF Audio Players & Recorders
I do not know how to connect the woofer KEF PSW3500 to the amplifier Denon 4310. BCC sold me a 1 on 1 plug, but the woofer needed to plugs (left and right).
Bass is mono directional in the main,and while your sub has a left and right input ( because a few amps do have left and right sub outs) only one of them is required (usually marked as MONO on the sub). You can also get a Y splitter phono adapter and connect the single cable you have to both sockets, which is how I have mine set up. This is most common
Dec 03, 2010 | KEF Audio PSW3500 Subwoofer
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
I have a KEF KHT 2005.2 Subwoofer that does not produce sound any more, it makes a slight pop sound when i switch it on and thats it, no further sound. The system is about 5 years old but has not had a lot...
The KEF-Subwoofer range (from the PSW1000 up to PSW 3000?) have some built-in flaws in the electronic design.
I just fixed my PSW2000 working along the repairing instructions from:
http://lug.demon.co.uk/kefrepair/
Works! Costs have been about 35,- Euro for spare parts and some (too many) hours of work. If you are used to electronics and soldering you may make it in 2 hours.
Nov 07, 2009 | KEF Audio KHT 2005.2 System
KEF Subwoofer PSW2010 (KHT2005.2) - No power
chik power sours first
thaen chik transformer inside
u will see it burned if so chang it
Aug 18, 2009 | KEF Audio KHT 2005.2 System
Sub doesnt put out a sound
go into your sound properties and make sure your sub is turned on or not muted there should be a seperate one for sub just like you have one for speakers
May 26, 2009 | KEF Audio KHT 1005 System
Kef subwoofer kht 2005:2
check for the connection og the main wire is cut.. or check the supply..
Dec 07, 2008 | KEF Audio KHT 2005.2 System
Psw 3000 sub
I had the same problem. It is a loose conection on the print. The Amp unit goes into failsafe mode. You can check the Rc control. You are only alowed to turn it on and off. No signal regulating.
The solution is to remove the backside, and check the print for bad connections or even broken parts.
I experienced one leg on a transistor tha had broken.
Good look
Aug 11, 2008 | KEF Audio PSW 3000 Subwoofer
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
KEF Audio KHT 2005.2 System Logo
415 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
