Question about Dell Inspiron 9100 Notebook
Processor not recognized
Instpiron 9100 early 2004,
p4 3g 1m l2 cache socket 478 prescott
only reaches bios setting screen will not boot to windows,
bios ao03 installed , ao06 available,
how do i flash bios to update without windows?
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    BOS updates are done without windows .. but if this is the only macine you have to go get the BIOS uodate with .. Well .....
    President:
  • 1,073 Answers
Updating bios is outside windows.
Use another computer and download the bios, save it on a floppy, cd or usb
Put the floppy, cd or usb in your pc, change the boot on your pc, let the pc start from whatever u sored your update on
The pc will now update your bios since thats an automatic procedur.
Dont forget to change your boot back to your HDD
Good luck
Posted on Dec 06, 2008
Upgrade of microprocessor
I reckon this upgrade is not possible because the m/b hardware doesn't support the SL7E6. It's not listed amongst the processors available for that model (highest speed one listed at 3.2GHz), and the specs imply that L2 cache must be 512MB or less. (This answer is not definitive)
14.April.2014
Jan 25, 2013 | Intel Computers & Internet
CAN NOT SUPPORT 2.8/1MB/533
That's because your motherboard only supports Northwood chips that have a L2 cache of 512 K. The chip you are trying to use is a Prescott chip with 1MB of L2 cache.
Your best bet would be to buy an INTEL Pentium 4 3.20GHz/512/800 Processor SL6WG Socket 478. It is a Northwood chip with an 800 fsb and has hyperthreading. There is a 3.40ghz model, but you can get the 3.20ghz chip much cheaper.
Here is your motherboards specs page:
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-51078
May 19, 2012 | IBM ThinkCentre S50 8183 - P4 3 GHz...
CAN NOT SUPPORT 2.8/1MB/533 PROCESS
Here's your motherboards specs page:
Does the MB support an Intel Prescott 3,06 ghz fsb 800mhz processor?
that is a socket 478 board. it supports northwood and early prescotts. prescotts at 3.06 with the 800mhz fsb were made in both socket 478 and lga 775 forms, so you have to make sure that your processor is indeed a socket 478 model.
Nov 06, 2010 | Abit IC7-G I875P;SOCKET 478;800MHz...
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
Yes, it will work just fine, as you can see for yourself - on the mb's link is the third processor from the second group (Prescott).
Jun 03, 2010 | MSI PM8M-V Motherboard
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
Can this board support 1m L2 cache?
Your manual will tell you what the motherboard can support . If it a pre-manufactured motherboard ( A.K.A a dell , gateway , sony vio , HP .. ect ect ) then more than likely the answer is NO
Jul 26, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Jun 02, 2008 | Asrock Computers & Internet
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
Dell Inspiron 9100 Notebook Logo
188 people viewed this question
Alun Cox
