Question about Hoover U5420-900 Bagged Upright Vacuum
WIndtunnel TurboPower U5400-900 sensor light flashing even though I just changed bag
  • 125 Answers
They do this as a matter of course. its a poorly designed vacuum. Hoover doesnt exist any more, it is actually a dirt devil
after years in the vac repair business, i reccommend that you look at panasonic the next time
Posted on Dec 06, 2008
Help - vacuum cleaner heating up and stopped working
Check for clogs in the hose and suction path. Replace bag and filters. The vac is designed to turn off when over heated.
Sep 10, 2014 | Hoover U59 WindTunnel TurboPOWER Bagged...
I have a Hoover Turbopower 5100 . I have power, and my spinner turns. But I have no suckson power. I look for and blockage. couldn't find a thing. what's wrong?
Same problem here, after 1 month of use, it just wont suck on the bottom side, the hose works correctly with the accessories, but the bottom wont suck, the brush works fine by the way. I removed the hood checked the inside, looked for clogs and nothing.
Oct 01, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
My sweeper won't pick up anything could the belt be broke
It may be broken or it may be stretched. Belts can become stretched and will lose elasticity.
Jan 26, 2011 | Hoover U59 WindTunnel TurboPOWER Bagged...
Hoover wind tunnel not picking up properly
My turbopower 6200 does not seem to be picking up. The beater bar I don't think is working?
May 01, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
When i move the switch up,the motor doesn't start. its a turbopower 52oo .is there a rod that activates the switch? for the last 2 uses it ran as soon as it was plugged in.
the rod on those are so flimsy when the switch gets old it gets stiffer to operate and the rod just bends away. replace the switch and it will fix the problem.
Jan 02, 2010 | Hoover U59 WindTunnel TurboPOWER Bagged...
Hoover vacuum cleaner indicators stuck
the sensor is located in the tube that the bag mounts to, if you take the bag off of the unit and have an air compressor handy you can blow out the port hole this should dislodge the particulates that are causing the false reading, there is defintely a clog in the system. let me know if this helps thanks Don the Vacuum Doctor Alb, N.M.
Nov 05, 2009 | Vacuums
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Sensor wont go to green
Try cleaning the dirt sensor. It's usually located where the bag connects to the vacuum. Take the bag off and clean the inside of the tube that goes into the bag with a damp cloth.
Jan 11, 2009 | Hoover U5450-900 Windtunnel Supreme Bagged...
Hoover U5420-900 Bagged Upright Vacuum Logo
65 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
