Question about RIM BlackBerry Pearl 8100
FDN Fix Dial Numbers
My Blackberry Pearl's numbers 2 5 8 and 0 are not working. I try to dial but it is not allowing me. I cannot check my voicemil due to my code, is one of those numbers. Please HELP ME!
ASAP
Thankssss
    Problem Solver:
  • 15 Answers
Alright, this is because the center column on your Blackberry has somehow been disconnected from the processor. This can not be solved by you unless you want to take your Blackberry Pearl apart into many different pieces. Instead, if your phone is still under warranty, you should sent it in to be fixed.
Posted on Dec 06, 2008
  • waiwai933 Dec 07, 2008
     Hi! If this solution fixed your problem, please click the "Fixya" rating. If it didn't, please click the appropriate rating. This helps me improve my assistance and the time that I can spend here helping people just like you. :D
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
What does outgoing call are restricted by fdn mean
FDN(Fixed Dial Number) if enabled, allows you to restrict your outgoing calls to the limited set of phone numbers that are included in the Fixed Dialing Number list.
Jun 10, 2014 | Motorola Mobility Verizon Wireless Droid...
Outgoing calls are restricted by fdn
This means that Fixed Dialing is enabled to certain numbers. You'll have to disable this function in order to call other numbers.
Mark
Motorola Support
What does Fixed Dialling Numbers mean?
Fixed Dialing Numbers or FDN list is a SIM card based security feature which allows the phone to be "locked" so that it can only dial certain numbers, or numbers with certain prefixes.
A PIN2 code (numeric password) protects the allowed list of numbers from being changed by any person who does not know the PIN2 code.
In FDN mode, your device will restrict outgoing calls, except for the numbers stored in the FDN list.
To activate FDN mode,
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Enable FDN.
2.) Enter the PIN2 supplied with your SIM or USIM card and select OK.
3.) Select FDN list and add contacts to be used in FDN mode.
To De-activate
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Disable FDN.
Warning: PIN2 is a serious SIM-based security feature of the handset. If you are not sure of your PIN2, please do not enter random PIN2. When you access a menu requiring the PIN2, you must enter the PIN2 supplied with the SIM or USIM card. Contact your service provider/ Network for your PIN2. If the wrong PIN2 code is entered three times in a row, PIN Lock(PUK2) will be automatically activated.
Oct 31, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
Buttons on the blackberry pearl
clear sign of water damage under that button. 8100 is fairly easy to open with a T6 screw driver. then use alcohol to clean the area under that button. you need to also remove the while keypad membrane and clean under it as well
Jun 10, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl 8100 - Cant dial a "0"
i suggest sending it back to where u purchased it because there is probably an electrical malfunction
Feb 10, 2009 | RIM BlackBerry Pearl 8100
No radio path unavaiable for blackberry pearl
All you need to do i Change it from "Line 2" to "Line 1" or vica versa. press dial to access your last dialed numbers...and at the top of the screen you will see the options
Dec 07, 2008 | RIM BlackBerry Pearl 8100
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
RIM BlackBerry  Pearl  8100 Logo
99 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
