Question about SanDisk Sansa e260 MP3 Player
E220 refresh data base
Hey guys i think i have tried everything posted here to fix this but it seems that my device cannot update to solve this problem. another thing is that my pc pics up a 16mb storage device and not the actual 2gig and not even the memory card inserted. please help!
  • 8,596 Answers
You will have to reformat the player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Desktop software wont load my applications
First thing to try is disable the computer firewall and virus scanner.
Feb 10, 2014 | Blackberry Cell Phones
How to solve e220 and e218
Both of those errors revolve around the laminator.
E220 is Lam2 Tag Error
E218 is Lam 2 Head Lift Error
I would recommend replacing the laminator.
Sep 19, 2013 | Office Equipment & Supplies
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Refreshing data base
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
Jun 23, 2008 | SanDisk Sansa c140 MP3 Player
Hey, need ur advice again
I posted the files online to update or reload the firmware on the fd400:
these should still work...
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
Mar 28, 2008 | Fine Digital FineDrive 400 GPS Receiver
Player update required!!I
lol get the warranty n send it back to the manufacturer n ask for all the files to be restored b4 u get it back
Jan 14, 2008 | iRiver E10 Digital Media Player
Sansa 250R ~ It will not reformat
how can i refresh the data base, tks
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
It refreshes the database to build the menu for you to navigate.
Your device may have corrupt data in it and therefore takes longer than normal to build the library.
You can format the device to remove everything, and then re-transfer them to see if that helps.
To format in My Computer>Device Name (e250)>right Click and select format.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player freezes at refresh database
The Same thing happened to Me once. All you have to do is reformat it. You can do this by first putting the player in recovery mode. You can do this by putting the hold button on the side where you can see the orange and then plug the device into the computer while holding the power/Menu button. Then go to my computer to Verify that it came up as 16MB-Format. Then you can type into the address bar and type in http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip. then once you do that right click on the file you downloaded and select open with compressed folder and drop and drag to the 16MB-Format drive. In the 16MB-Format drive folder select file menu and select New - Folder and rename it sansa.fmt then press enter to save. Finally move the hold switch back and disconnect the device and look at the screen and verify it is formatting and resetting once it's done and finishes the updates restart and if needed pick your language. check and see if you can use your player.
Mar 26, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
