Question about Avid Color Correction with Media Composer Adrenaline and Xpress Pro (05500332101)
Avid Media Composer software Digital Cut
I am trying to do a digital cut using the Avid Media composer software. Whenever I try to do this I get an error message saying that there is an issue with drop frame and non drop frame. I cannot find anywhere where I can switch between the two.
0 characters
1 Points
When I cut and paste a photo from internet explorer 10 to Microsoft digital imaging 2006 the only thing that shows up in a weblink ??????
Yes that is the weblink to the picture. Unless you have purchased software to download pictures, you will not be able to do that.
Oct 20, 2013 | Microsoft Digital Image Suite 10
How to make a promo vedio
In the attached link, the training video named "From Avid Media Composer to DVD in easy steps" may help you.
Mar 18, 2010 | Avid Xpress Pro
I am trying to use my DGI Cutting Plotter and when i try to start up the program Omega Cut Pro it comes up with a message to say 'Protection Failed, Please Check Your Dongle' I am unsure what this means...
Ok this means that to use this software you MUST have a licence and along with this you get a "Dongle" a device that plugs into either the Serial, Parallel or USB port, and has a "Code" in it, that is "Read" by the software. You simply cannot use it without this "Dongle" & Licence.
Feb 10, 2010 | Graphics Publishing, Design & Multimedia...
I am a Pinnacle Studio user
Avid is a complete different animal. The logic is backwards from Pinnacle or premiere. If you're used to those, Avid will seem like a forgeign language. Also, projects aren't compatible with Avid.
Dec 30, 2009 | Pinnacle Avid Liquid Version 7 for PC
Cannot install the program --it keeps telling me i need windows SP2 when i know i have up-to-date SP3 installed
Try to use this software to see if your windows updates are all right (Microsoft Baseline Security Analyzer (MBSA)):
After that try to see if the program works
IF NOT then I will try to reinstall the program
IF it still not works you can contact the Pinnacle support team here :
Hope that helps :O)
IF NOT then try to return here
have a nice day
Please rate my answer
Nov 17, 2009 | Pinnacle Studio Plus Version 11
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
Aug 26, 2009 | Avid Xpress Pro 4.8.1 Full Version for PC,...
No sound in Pinnacle Studio Plus 11
This applies for windows vista only please check the volume control on the lower right corner in your desktop. Try to click the volume control icon then click the MIXER then look for the pinnacle studio program probably it might be muted.
Apr 20, 2009 | Pinnacle Studio Plus Version 11
Studioplus initialization failed message
This might help to fix the problem
Jun 01, 2008 | Pinnacle Studio Plus Version 11
Graphics Publishing, Design & Multimedia Software Logo
54 people viewed this question
Top Avid Graphics Publishing, Design & Multimedia Software Experts
Are you an Avid Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
