Back to:
Tags:
Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
What would cause the outside part of my air... (by 2 users)
By Rogers - usenet poster
What would cause the outside part of my air conditioner to frost over?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by pthrndr1pa, posted on Feb 29, 2008
Air from our heat pump was cold. we checked the outside unit, found ice on condenser. how do we fix it?
Best Solution
posted on Aug 08, 2005
Helpful (85)
Cato
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Because of high humidity in the air, the evaporator gets cold enough to cause the extra moisture to freeze. This could happen if you are low on refrigerant or if your coils or filters are dirty. If you are low on freon, you most likely have a leak and should hire a professional to fix this.
A temporary fix is simply to turn off the unit until it warms up/thaws. Then turn it back on. But this is not a permanent solution. Clean any dirty coils or filters and if this doesn't fix the problem, have a professional check for leaks and refrigerant levels.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on What would cause the outside part of my air conditioner to frost over?:
I don't want to Accept this solution
Solution #2
posted on Jun 25, 2008
Not Rated (0)
ejreddix
Rating: 0%, 0 votes
How do you clean the dirty coils? I believe they are located in the attic. What solution should be used to clean them? The filter I purchase is one for trapping allegens and this was installed in May.
Also, what this type of cleaning be label a maintenance checkup?
Thanks,
ejrnet
Thank You!
Solution #3
posted on Aug 22, 2007
Not Rated (0)
KAKAR
Rating: 92%, 3 votes
I SUGESTS THE UNIT IS DIRTY ALSO THE CONDESER AND EVAPORATOR ARE DIRTY
Thank You!
Solution #4
posted on Jul 27, 2007
Not Rated (0)
cccgipson
Rating: 75%, 3 votes
The evaporator (inside coil) icing up can be normal under certain conditions. The problem isn't caused by high humidity -although it won't happen at low humidity conditions-, it can be caused by several factors (or combination of factors)- running your thermostat at the lowest possible setting while the temperature is 70 deg. F or below outside, running the fan speed on low, a dirty filter, a leak, a restriction in the refrigerant circuit, etc. If you are low on refrigerant, you DEFINITELY have a leak. An air conditioner doesn't use refrigerant as a car uses gasoline. It is a sealed system and will never need any refrigerant added unless it leaks out. I would first check your filter, then check and see that your thermostat isn't set on the lowest possible setting. Don't run the a/c when the outside temperature is below 60 degrees unless you don't mind it icing up. Make sure the air outlets in the ceiling aren't shut off and check to see that no one has blocked the return air grill with a piece of furniture. If none of these solutions helps, then call a professional.
Thank You!
Can you Help with these Air Conditioners problems?
Air Conditioners
Vaillant ecomax heating works but no hot water
Air Conditioners
Burner is not turning on,however when pressing button on...
Air Conditioners
no cooling
Whirlwind -Air Cooler with Heater and...
I have a 30 # cylinder of R22, I have the gages, how do I...
water fill light stays on all the time even when water...
Loading problems.
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
