Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
Doesn't shut off when hits thermostat temp
I set it at low and it kjust keeps running. Just started doing this - not shutting off when it hits the temo it is set at
  • 1,420 Answers
Remove the top section of the heater. You will notice at the lower Right Hand of the back of the heater a small black plastic bulb with a yellow wire. This is the sensor fot the unit. Take a microwavable bean bag and heat it up in the microwave to a temperature a little greater than your body temperature. Place the bag on the bulb and then try and start the heater. If the heater does not start, your sensor is working but may need to be relocated. If it still runs, call a technician.
Posted on Aug 30, 2007
    Novelist:
  • 114 Answers
THESE HEATERS HAVE A COPPER COLORED REMOTE SENSING BULB THAT HAS TO BE MOUNTED IN THE AIR FLOW. THEY ARE ONLY HELD ON WITH 2 CLIPS AND CAN BE KNOCKED OUT OF POSITION ... TAKE OFF THE FRONT COVER AND MAKE SURE THE BULB IS IN THE PROPER MOUNTING POSITION.
Posted on Apr 28, 2007
SOURCE:
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
I have it all set up..programmed a work out...it starts to work..but the tread itself that you walk on wont run..what do I do?
From the User manual....here
http://servicedocuments.com/pdfs/_0005_SOLE/_0005_SOLE_01_Treadmills/003_OwnersManuals/2010_2011_SOLE/F63_F65_OM_810.pdf
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
My imac keeps freezing withen 3 hours.
You can do this with the built in program Automator. Hit record and Automator will follow your actions and turn them into a script. You can then set the script to run in the interval you requested. http://mac.tutsplus.com/tutorials/automation/10-awesome-uses-for-automator-explained/
Nov 10, 2013 | Computers & Internet
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
Car keeps shutting off on me
try cleaning the throttle body and have the throttle position sensor checked.some throttle bodys need to have a basic setting performed with diagnostic machine.
Oct 12, 2009 | 1996 Volkswagen Jetta
Air conditioning condenser always runs, never shuts off
Ok where do you set thermostat [stat]at? to low the normal A/C unite will only satisfy to certain temp if to low will just keep running. where is the Stat in the house sun on it? is the house cooling down. do have lots of window facing West if so large heat load or East. how large is the house maybe to small of a unite. try setting up at 79 see if shut down. hope this Help Paul
Jul 07, 2009 | Heating & Cooling
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
Overheating
215 is not overheating. Does it keep getting hotter the faster you go? Does it cool off when slowing down or at idle? Does the Fan clutch or electric fan come on? When the engine is this hot.
Aug 09, 2008 | 2006 Chevrolet Cobalt
COMPRESOR TROUBLESHOOTING
This is a typical symptom of having an A/C system low on freon if it cycles on and off when first turned on or very soon afterward. All types of A/C units for home and auto have a low pressure cut-out switch that will disengage the compressor when the freon level drops low enough to cause damage to the compressor. The unit needs recharging with the proper amount of freon to correct the problem. If it's an automobile A/C system and the freon level is okay, it could be a faulty compressor clutch or coil.
Oct 16, 2007 | Coleman Mach 15 Air Conditioner
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
Top Rinnai Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Sheldon Dedek
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
