Question about AEG Dishwashers
Not heating water. aeg favorit 86070 vi model
5 Suggested Answers
SOURCE: AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Posted on Nov 09, 2008
joe_lishman
  • 192 Answers
SOURCE: aeg favorit 86070 vi fully integrated dishwasher
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Posted on Jan 19, 2010
SOURCE: in which way can i reset my dw AEG favorit F 86050
There are 6 program buttons on the right side of the On/Off button.
Press and hold button 1 2 ( 70
Posted on Oct 12, 2010
SOURCE: Our AEG Favorit Sensorlogic Turbodryis
i have the same problem, i have a machine that is 2005 model and it does not heat the water or dry in the end
Posted on Oct 20, 2010
I have a AEG Favorit 65011 VI dishwasher which stops in the middle of a programm an shows error ,60 that is not mentioned in the Users Manual. Can you please help me?
Fault in heating phase. Could be:
Heating element, wiring between heating element and power board,
power board (usually relay). Sometimes can help to resoldering (cold solder joint) or replaced relay on power board.
Dado
Mar 10, 2015 | AEG Dishwashers
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
The temperature must increase by a certain amount at each step.
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
In which way can i reset my dw AEG favorit F 65450 vi?
Hold and press the end cycle by 5 seconds, and try again. However you can disconnect the c.breaker by 5 seconds too. and try again.
Merry Christmas.
Dec 19, 2013 | AEG 24 in. Favorit 86050Vi Built-in...
My dishwasher aeg favorit 50870 not use hot water(not do hot water)
If the water isn't getting hot, then either the water inlet valve that opens the hot water is faulty or the heating element that heats the machine may be bad.
Sep 29, 2010 | AEG Dishwashers
In which way can i reset my dw AEG favorit F 86050 vi?
Sep 04, 2010 | AEG 24 in. Favorit 86050Vi Built-in...
Water not heating on AEG Favorit 40850.have replaced heater but still not heating.any suggestions
I too have had this problem. I switched to the hottest setting from the economy one and it heated again. Once I switched back it was OK for sometime but has started to do this again.
Jan 30, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Aeg favorit 86070 vi fully integrated dishwasher started bleeping with 3 short bleeps 2 months ago. I followed instructions internet and shook dishwasher to one side and it worked for about 8 weeks. Now...
Sep 09, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
Aug 19, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwashers Logo
64 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
