Question about Technics SL-1210 Turntable
1210 internal fuse keeps blowing
The internal fuse of my technic (the horizontal one) keeps blowing i have replaced it 3 times in as many weeks.The problem seems to occur when i place the stylus on to the record i can turn on the deck and it lights up and turns but if i put the needle on the record it instantly blows the fuse.
I tried swapping the stylus over and it worked for a while with the needle on the record but if i pulled the record back and forth (scratch) it blows the fuse?
could this be a faulty wire in the arm?
  • 515 Answers
First and foremost, the tonearm has absolutely NOTHING to do with the power. They are not connected in anyway. The only thing that links them is the tonearm is grounded to the chassis of the turntable. Nothing else. However, this will not cause this sort of problem.
Turn on your turntable without using the POP-UP light - keep the light down/off. Try it then. If it works, than the issue is there. If you still have the same problem, then the issue is something on the main drive circuit board which is overheating, and the fuse is going to protect the unit from any damage. Take a look at R213 - see if it's burnt around it's area. If so, more than likely this is the culprit.
This is not an easy diagnosis. Highly recommend taking it to a service center.
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
My 1210 mk3's keep's popping the internal fuse?
Sounds to me like the capacitor across the motor needs replacing. On the + and - on a motor is a capacitor. This might be the problem, replace it as it should not be too expensive, you can never tell. Some times they are a few pence other time they are a few pounds. Why I don't know. If it's a common one, a few pence if it's a rare one, pounds....... I hope this helps.
Jun 29, 2012 | Technics SL-1210 Turntable
Internal fuse on Technics 1210 Keeps Blowing. Hi there, I have been asked by a friend to repair his decks, I have little electronic knowledge but am having a crack at it any way :) Problem is the Fuse F1...
this was happening last mine with mine aswell i just replaced a fuse then it started to work??
One fuse had colouring on it which i did not know what it meant sop i didnt touch that.
So have you changed both?
Oct 20, 2011 | Technics SL-1210 Turntable
Me technic 1210s wont *** on ive tryed change in the fuses wiv 1 from tv an still nothing any ideas?
It could have got an internal fuse, not the one in the plug. Also the power switch might have broken. There's only one way to find out! Take the bottom off and have a look.
Jan 12, 2010 | Technics SL-1210 Turntable
Engine Dies while driving down the road-frequent fuse/electrical
If the computer fuse is blowing, there are deep problems within the computer--it must be replaced. There are no high current loads external to the computer that could draw that much current from the computer. All high current loads are driven by an individual relay for that function which in turn are driven by the computer. Even if a relay coil shorted internally, the computer output would not likely fail. A test would be to pull all relays, then replace the fuse. If it pops again, the computer is suspect. (several hundred dollars for a rebuilt unit). Hope this helps.
Aug 28, 2009 | 2005 Pontiac Aztek
Technics sl-1210mk2
this should help determine which one goes where but they may be the same , so it wouldn't matter if they have the same voltaage and amp. rating
Apr 18, 2009 | Technics SL-1210 Turntable
Internal fuse
The Solution:
1. Firstly unplug the decks!!!
2. Remove the slipmatts and platter
3. Unscrew the circular plastic cover (Note: 5 screws holding it down)
4. Upon removing this circular plastic cover you will see a clear piece of plastic covering a circuit board, open it up. Now you will see a two fuses one clear and one stripey. 5. Remove the fuses (Gently poke it out with a pen/screwdriver or whatever) and examine it and see if either or both have infact blown.
6. Bring the suspect fuse/s to any electric/hardware/music type store (or search the net) and try to get a replacment but make sure its the same as the fuse you removed!!!. A T250 mA fuse(clear) an a T1A Fuse (stripey) are stated in the Technics user manual.
7. Now get the new fuse and gently snap it back in to the silver holders.
8. Replace the clear plastic circuit board cover.
9. Screw back the the circular plastic cover (Note: 5 screws holding it down)
10. Replace the Platter and slipmats
Sep 04, 2008 | Technics SL-1210 Turntable
Internal fuse
remove platter remove plastic cover main fuse is there
Jan 29, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
319 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
