Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Dark stain on display screen
My Powershot SD750 has a dark stain on the display screen and on pictures when I print them. The dark stain is consistantly in the same spot. How can I get rid of this?
  • 76 Answers
It should be a stain spot on the camera lens..try taking it to an authorised service point and have it cleaned
Posted on Dec 07, 2008
Thw pictures are coming out black
should be a brighness setting you can adjust in the settings menu
Apr 30, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon PowerShot SD750 digital camera screen suddenly turn black(dark ), I can not take picture because there is no image shown on screen. I still can record sound on video,but no image. what is going...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A.
Dec 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I have canon sd 750. its lcd gets black. Shows pictures etc but view finder remains dark. display is zz. what to do?
Look for DISP or DISPLAY button in the lower-right corner of the back of your camera. Press this once while the camera is turned on. The DISPLAY button manually turns the screen on and off. This is to save battery power for extended use. You would then use the optical viewfinder in its place.
Oct 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera turns on but I see nothing except a dark screen
Many cameras have an option to turn off the display to save battery power. Hopefully it is just turned off and not damaged. Try to turn your display on. A local camera store or www.canonusa.com can offer more help.
If this helps please vote for my solution.
Jun 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
When i turn on my sd750, the back screen appears dark (cannot see what the camera is point at and when i take the picture, it is black ... in the past i was able to retify but putting on and off a few...
There usually is a button on the camera which will affect the LCD operation. On these Canons usually it is marked with a small monitor icon or it has "Disp" next to the button. This is on the surface of the camera and not in the menu. It will also be in the menu, but since you cannot see the lcd display, then I assume you have to try to use the buttons on the camera.
Dec 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Can't take pictures w/ flash
Maybe you have the ISO set to a very high number. Set it to "auto ISO".
Sep 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
LCD screen dark on Canon SD750 camera
Hi
If you can't take new pictures (they are totally black) but you can see old pictures, then either the lens aperture is stuck closed or your CCD is bad. Either means that you need to replace the lens of the camera.
You can look online for a defective camera and make one good one out of the two, but it's difficult to find one with a good lens!
Don't bother going to a store or 'service center' though you can if you would like to verify what I'm about to say. They won't know anything about camera repair, and will want to charge you $150 or more for the repair if they say they will do it. If they do take on the repair, all they will do is send it to Canon which you can do yourself for about $150.
There are AFFORDABLE digital camera repair businesses online, I know, because I own one! We can replace your lens for about $75.
Good luck with your repair,
Thomas D.
Owner; Darntoothysam com
Apr 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Dropped camera-two corners dark
Check what the actual pictures look like when they are downloaded to PC or to print. The problem may only be on the screen. It may be very expensive to replace the screen, but you might be able to live with it?
Good Luck
Oct 25, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
412 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
