Question about RCA D52W19 52" Rear Projection Television
The tv looks like it is in wide screen it is a rear projection
It is doing the hour glass effect
  • RCA Master
  • 5,138 Answers
Resolder all of the big power diodes.
Posted on Dec 10, 2008
Cracked front glass
U out of luck,not worth to replaced the screen,the screen it same as the new tv.The tv compannies sell out tv screen as a new tv.The tv 95% worth is in the screen.
Dec 23, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
The tv you sold me
pin cushion is gone.
time to get a new one.
don't try to fix it. not worth the time of the money.
Sep 24, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Samsung sp42w5hfx rear projection tv
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Mar 06, 2008 | Samsung PCL545R 54" Rear Projection...
Hitachi 51SWX20B's screen has 3d effect
Feb 15, 2008 | Hitachi 51SWX20B 51" Rear Projection...
What is wrong with my tv
Feb 07, 2008 | Hitachi 50UX57B 50" Rear Projection...
Philips 9P6034C103 - Urgent Response Appreciated
Was the hour glass upright or sideways? From what you described I would say you have a pin-cushion problem. Let me know if you need any additional info.
Feb 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
RCA D52W19 52" Rear Projection Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
