Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Tv has a dinge look to the picture
My Tv has a dinge look to the picture . I have all of my Three colors lit . I know it has a filter some .Please help.
  • Philips Master
  • 3,459 Answers
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become  cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Dec 22, 2008
Why does my sony 45 inch screen have mostly green color?
the color tv display used mixing of three colors, (red, green and blue). it lost one color, coomon problems: lose contact of base of picture tube or its wiring, sockets, capacitor dead in rgb section, dead video ic
Oct 05, 2014 | Sony KP-FX432M91 Projection TV 43 WEGA, 3D...
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
I'm getting a curved(fisheye) picture with the three colors not lining up.
This kind of picture appears due to failure of convergence output section in rear projection tv, please check convergence output chips and replace them (tv has two chips of same number)
Let me know if you have additional question.
Thanks.
Feb 03, 2011 | Sony KP-51WS500 51" Rear Projection...
My panasonic dlp model pt43lc14 shows yellow picture
there are many mirrors, filters and lenses in the projection assembly, This happened to me too. I took the assembly apart and there was one of the filters that had gotten charred. I peeled off the plastic filter and cleaned the glass it was attached to then put the TV back together, now have a perfect picture again.
Dec 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
I might have issues with my color wheel, Im bnot recieving a picture with full color!
if tv is lcd it has three color filters which can be damaged by heat.If it is dlp then it has a colr wheel which spins.they are located in the light engine.alcd tv has 3 lcd panels a color filter(red green or blue)is mounted behind panel coloring light going through lcd.prisms combine pictures before going through lens. If color burns off of filter then color of picture is affected
Oct 19, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Spots on picture screen,color not correct
the picture tube has three color production units (bulbs) red, yellow and blue.....since these three colors can be combined to produce almost any color. as you have specified the red bulb might have damaged due to one of the following reasons.
1.continuous usage
2. keeping your tv in standby mode for a prolonged time.
the only thing you can do is call a technician and get your damaged part replaced.
remember please do not try to disassemble the unit yourself.
May 28, 2009 | Panasonic PT-52DL10 52" Rear Projection...
Canon powershot A85 camera, only seeing black and white on TV
Please check Yellow video connector in TV and hook camera video cord there to see color picture of Canon A85
Feb 20, 2009 | Nikon Coolpix 5600 Digital Camera
Color distortion and arched picture
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Very Dark Picture
This sounds like a typical problem in the sweep power supply.. theres a filter capacitor for the CRT screen voltages that is most likly open or changed value. the first clue is that you get all your colors on the convergence. this is a high voltage circuit and should not be messed with by the user unless they have solid state repair exoperience and know all the high voltage saftey factors involved. Please call in a trained tech to assist you in this matter. Good Luck
Oct 08, 2006 | Toshiba 42H83 42" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
