Question about Dell Dimension C521 PC Desktop
Dell c521 won't start
Dell c521 seems to fail POST test. Yellow power light on steady, fans running. No diagnostic # lights on. BUT network symbol light on and yellow light on back at ethernet connection is also on. Could this be problem with network card?? Cannot disconnect as it is built in to MB??
Any ideas??
  • Anonymous Dec 12, 2008
    I have this exact problem.
  • azimbutt126 May 06, 2009
    I have
    when i plugged power cord PC comes on with yellow light and fan running nothing eels. My hard drive is good. Any idea.
  • 28 Answers
- disconnect the hdd and optical drive cables, remove the expansion card, reseat the atx and 12v cable and turn the computer on. if the power led is glowing green connect the devices on by to find what device is causing the no post issue. after the strip down if the power button is still yellow replace the motherboard
Posted on Dec 19, 2008
Dellc521 says i have no sound device
Posted on Dec 29, 2009
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Do not want to start, yellow light on and fan on only.
At a glance it seems that your MOBO is bad.But also can be the power supply.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 21, 2011 | Dell Dimension C521 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Older Dell 8200 will not power on. When plugged in the power light blinks amber, and it will not respond to the power switch. If I swap out the cpu for an extra celeron I have lying around the fans power...
To better troubleshoot your issue take a look at the 4 diagnostic lights on the back of your PC, they will give you more information and possible solutions. HERE is the link to what the lights mean on your model PC.
Diagnostic Codes Your computer is equipped with four diagnostic lights, which are labeled "A," "B," "C," and "D" on the back of the computer. Each of the four lights can be yellow, green, or off as shown in the following table. When the computer is turned on or restarted and it is functioning normally, the lights flash during POST. After the computer starts, the lights remain green to signify normal computer operation.
If a malfunction is detected and the computer fails to start, the lights display a code that identifies the problem. Write down the diagnostic code displayed and look it up in the following table.
Aug 30, 2010 | Dell Dimension 8200 PC Desktop
Solid amber light with fan running, so i assume the power good signal is being received, no diagnostic lights and no POST. I've disconnected and substituted all the drives with known good parts, bought new...
Please let me know if the numlock light responds by pushing the numlock key on the keyboard. If you are using a videocard, please disconnect it and connect the video cable to the integrated video. Make sure you disconnect all the expansion cards. Please let me know if this doesn't work.
May 20, 2010 | Dell Dimension C521 PC Desktop
Have a dell dimension 4700 with orange steady light?
Turn the machine off and unplug the AC power then hold the power button in for about 30 seconds to drain any residual power. Plug it back in and turn it on, when you see the Blue DELL word press CRL+ALT+D and this should run a diagnostic on the hard drive. If it runs ok you will get a pass or fail on the hard drive. If you cannot get the diags to run you might have a bad power supply or motherboad/processor. I would find a known good power supply and try it before the motherboard.
Mar 09, 2010 | Dell Dimension 4700 PC Desktop
I have a dell studio 1737 motherboard f238n with ati graphics and i was wondering if an intel t3200 would work with that motherboard. The reason i ask is when i hit power the lights above keyboard come on...
what is the color of the LED ight on the power button? if it is a steady amber it might be a NO POST situation. if the LED lights up normally without the fan spinning and no display on the monitor, then it is a NO VIDEO issue. you can try to power it up and at the same time initiating diagnostics by holding down the <Fn> key while powering on the system. It should show up after a few seconds with the PSA (Pre-Boot System Assessment running.
another way of testing for video integrity will be the LCD BIST. it is done by holding down the <D> button on the keyboard while powering the system on. It should show color bars during the test. you can also try to drain the flea power by removing battery and the adapter then depressing the power button several times.
if those fail, then a motherboard replacement will be the best resolution.
Feb 26, 2010 | Dell Studio 1737 Laptop
Cannot start up the dell c521, fan is loud and light is orange.
What you are describing is a no post failure. Disconnect all external devices, see if anything changes. if not, replace the motherboard
Oct 28, 2009 | Dell C521 DimensionTM PC Desktop
Motherboard change
check on system lights... what are the diagnostic lights telling you??
if the 4 lights are off you may have a problem with the led itself or the powersupply is just messing with your head.
Dec 02, 2008 | Dell Dimension C521 PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension C521 PC Desktop Logo
2,428 people viewed this question
Alun Cox
