Question about Samsung SCH-a670
Store display mode?
I cant click any of the buttons on my cellphones except for the power mode to turn it on, to turn it off i need to remove the battery , when the phone turns on i can see the screen , everything in the screen is fine, the displays are all fine, on the bottom banner the time and date display flashes intermittently with a " verizon wireless" banner, as if it were in a preview mode used to display at a store. i can see when people call or message me but i cant answer the calls or reply the messages, i basically cant do anything at all, except but viewing the time or whoever is calling me. i cant even adjust the volume or ringer type. any help is appreciated thanks
  • 94 Answers
This is a common fault with samsung phones , you will need to replace the keypad with a t6 torx screwdriver or you might need a special kind. message me for details if your stuck. Hope i helped
Posted on Oct 17, 2007
SOURCE:
Cant get demo off on a samsung tv LE32C450E1W
Try doing the same thing, except instead of holding the menu button, hold the power button
Aug 29, 2012 | Samsung Televison & Video
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
Demo mode rs255sl
This function is for a display purpose on the floor of show room or store.
1) Mode ON/OFF
1-1) For the exhibition mode, press Power Freeze and Freezer Temp. buttons simultaneously for 8 seconds until a
“ding-dong” sounds.
1-2) Press the same time buttons again for 8 seconds to cancel this mode put with a “ding-dong” sound.
2) Operation
2-1) Most of the system function except the compressor operation are working properly.
2-2) There is no defrost cycle in this mode.
Mar 21, 2010 | Samsung RS265LBBP Side by Side...
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Unresponsive buttons because of engaged zoom
the reason why the lens zooms out is because the zoom switch is faulty and might need replacing.The way to tell this is when you switch it on in camera mode you will see the zoom bar displays on the lcd and stays there.
Jun 01, 2008 | Panasonic DMC-FX07 Digital Camera
Upload fotos
Here's how...
  • Starting PC mode
If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
In this mode, you can download stored images to your PC through the USB cable.
The LCD monitor on the camera is always turned off in PC mode.
  • Connecting the camera to a PC
1. In any mode, except Voice Recording mode, press the Menu button.
2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
5. Press the menu button twice and the menu will disappear.
6. Connect the PC to the camera with the USB cable.
  • Downloading stored images
You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
3. Select an image and press the right mouse button.
4. A pop-up menu will open.
Click the 'Cut' or 'Copy' menu.
- 'Cut' : cuts (i.e. moves) a selected file.
- 'Copy' : copies files.
5. Click a folder where you want to store the file on your PC.
Don't forget to rate this solution once you've tried it !
Good Luck.
May 20, 2008 | Samsung NV3 Digital Camera
Samsung SCH-a670 Logo
145 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
