Question about Onkyo TX-SR606 Receiver
Onkyo sr606 unable to select speaker setup in the menu screens?
Setting up a new set of speakers and want to adjust the dB of a single speaker but the menu for speaker adjustment isn't lit up to be selected, any thoughts why??
  • 17 Answers
Sometimes, the memory of the receiver will act abnormally.. what you need to do is return the unit back to factory settings. To do that, press and hold vcr/dvr button and while holding it, press the standby/on button. You will see the word clear. It would reactivate your settings. ^_^
Posted on Dec 16, 2008
خخخخخخخخخخخخخخخخخخخخخخخخخخخخخخ
Posted on Dec 06, 2008
I have an Onkyo TX-NR609 receiver that I'm very pleased with. I just upgraded my speakers to a set of Klipsche quintets with 400watt, 12" subwoofer. I don't want the text book answer o
You will need to go through the speaker setup menu and select the configuration and crossover frequency for the speakers. If you set to full range, your sub will not be engaged. Subs are only good at low frequencies, so use the lowest frequency for the crossover. (40-80Hz) If you have the audyssey microphone plug it and follow the directions to re-balance the equalization for the room and seating positions. If you don't use Audyssey, you'll need to tune all of the config setting manually. Some may be re-used if the distance is the same, but the loudness (+/- DB settings) and cross overs are probably going to be different for the new Klipsch speakers.
Jan 25, 2015 | Onkyo Audio Players & Recorders
My ONKYO TX-SR601 receive will not let me play my zone 2 speakers. I get a message saying '' Powered Zone 2 is not activated. How do I activate Zone 2? Thanks. Tom
Have just got a 607 myself, but it may apply to your model too.
Press the RECEIVER button followed by SETUP. On the TV screen a menu should appear and select SPEAKER SETUP then SPEAKER SETTINGS and set the powered Zone speakers to ACT.
SETUP will then return you to normal. Note: some other surround speakers will be switched off when ACT is on and ACT won't come on if Bi-amp is used.
Jun 13, 2010 | Audio Players & Recorders
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
Jan 19, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 bass treble settings seem to make no difference
I ran into the same issue and was stumped at first. Then I noticed somehow I had changed the sound processing to "Direct" which meant the signal coming from the source was bypassing all of the control in the receiver. All I had to do is select another option (press stereo for example on the remote) and kick it out of the direct mode.
Dec 21, 2008 | Onkyo TX-SR606 Receiver
Receiver - onkyo tx-sr606 problem - in the setup menu screen, option 2 "speaker setup" isn't highlighted to select like the rest. I am setting up new speakers and want to adjust the dB on a single speaker,...
if the speaker settings are deactivated, there is no other way but to reset the receiver back to factory settings. press and hold down vcr/dvr and then press standby. you will the word reset and that should activate your speaker set up again. hope this helps. ^_^
Dec 06, 2008 | Onkyo TX-SR606 Receiver
Lower volume on center
when you feel that the center channel is low compared to the other speakers, you can go to set up, speaker set up and then level calibration. here, you can actually adjust the volume output per speaker up to +12. So in your case, try to increase the db of the center speaker and see if that will help you hear it better. Hope this helps.
Nov 27, 2008 | Onkyo TX-SR606 Receiver
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
I have an onkyo tx-sr606 with speakers set up at 5-1 channel, when trying to set up the auto speaker set up i keep getting the speaker detect error message. what can i do ?
hi there. try to check if your surround speakers are on the surround terminal. do not put them on the surround back terminal because this is only allotted for the 7.1 speakers. hope this helps.. ^_^
Aug 12, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
345 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
