Question about Onkyo TX-SR606 Receiver
Receiver - onkyo tx-sr606 problem - in the setup menu screen, option 2 "speaker setup" isn't highlighted to select like the rest. I am setting up new speakers and want to adjust the dB on a single speaker, any thoughts??
  • 1 more comment
  • rex_oakman Dec 10, 2008
    Thanks for the input, much appreciated.
  • cmw31373 Mar 11, 2009
    how do I reset a onkyo 7.1 tx-sr606 receiver?
  • rex_oakman Mar 16, 2009
    I fixed this probelm by adjusting the TV audio off when the amp is turned on...
  • 17 Answers
If the speaker settings are deactivated, there is no other way but to reset the receiver back to factory settings. press and hold down vcr/dvr and then press standby. you will the word reset and that should activate your speaker set up again. hope this helps. ^_^
Posted on Dec 09, 2008
I had the very same problem tonight (no speaker setup menu (2)) and was about to do the reset as suggested by other poster... but then I noticed that the front of the amp was showing DIRECT just below the DD sign... this got me thinking that there must be a correlation between the DIRECT sound setting and the lack of speaker setup... (sound was only coming out of the FR and FL speakers - no surround and no Sub)
Essentially to fix this I had to review all my settings for the inputs and (iirc) the audio settings....
Long and short of it is that I was able to sort the problem without resorting to a full reset... I am a total newbie to all the AV amps and settings etc ... so am still playing with it so-to-speak
Hope this helps
Posted on Mar 14, 2009
How do i get out of dock mode when no ipod dock is conected on a onkyo tx sr606
hi
Have you tried powering it off fully (holding on/off button until it switches off) then leave it for 30 seconds, and switch it on again. hope this help.
Nov 29, 2014 | Onkyo TX-SR606 Receiver
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
Hi I have a tx-sr606 receiver. Tv connection is
go to menu and select manual input selection if it is on auto input select
Jun 04, 2010 | Onkyo TX-SR606 Receiver
Onscreen Menu does not appear when I push the Setup button on the ONKYO TX-SR606.
Do you have the monitor video output connected and selected on your TV?
Jan 22, 2010 | Onkyo TX-SR606 Receiver
Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
Jan 19, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 bass treble settings seem to make no difference
I ran into the same issue and was stumped at first. Then I noticed somehow I had changed the sound processing to "Direct" which meant the signal coming from the source was bypassing all of the control in the receiver. All I had to do is select another option (press stereo for example on the remote) and kick it out of the direct mode.
Dec 21, 2008 | Onkyo TX-SR606 Receiver
Onkyo sr606 unable to select speaker setup in the menu screens?
sometimes, the memory of the receiver will act abnormally.. what you need to do is return the unit back to factory settings. To do that, press and hold vcr/dvr button and while holding it, press the standby/on button. You will see the word clear. It would reactivate your settings. ^_^
Dec 06, 2008 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606 can not get it to work w tv using hdmi cables
try using a HDMI cable connecting the receiver from the "out" to the tv, then allocate through the setup menu what you have connected, say a cable box by hdmi, you would go to cable/sat allocate the port "hdmi1 or coax 1" then return. If it is a dvd click on dvd then allocate eg: "hdmi 2" then return.
Nov 16, 2008 | Onkyo TX-SR606 Receiver
I have an onkyo tx-sr606 with speakers set up at 5-1 channel, when trying to set up the auto speaker set up i keep getting the speaker detect error message. what can i do ?
hi there. try to check if your surround speakers are on the surround terminal. do not put them on the surround back terminal because this is only allotted for the 7.1 speakers. hope this helps.. ^_^
Aug 12, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
4,589 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
