Question about Amana Dryers
Problem with dryer timer/cycles
I am having a problem with my Amana Commercial electric dryer model # LEASOAW. The timer seems to be " out of sync" with the cycle markings on the control panel. Some cycles start in the middle of their marked cycle segment, running past the stop marking and on into the next cycle. Some will not start at all of shut off early. The only setting that seems to work with any consistency is the 60 minute marking in the timed dry cycle. I have replace the original timer with a FSP model # 505471P. The new timer is doing the same thing. I have checked the wiring schematic and all connections have been properly made.
  • 55 Answers
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
  • 185 Answers
SOURCE: Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Posted on Mar 25, 2008
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
  • 15935 Answers
SOURCE: Whirlpool duet electric dryer timer stopped
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
  • 1140 Answers
SOURCE: Dryer does not start. It is model LER7646EQ1. I
This sounds like several faults rather than one, but the likely original cause is the thermostat. Thermostats most often fail in the closed (on) position which would mean that the element was always on, rather than switching on and off when your dryer reached the correct temperature. This would explain why the control panel seemed hot.
This also explains why the dryer was stopping during the cycle. Your dryer is fitted with a thermal-fuse which trips and cuts power when the dryer gets too hot. However, a faulty thermostat doesn't usually stop the dryer running. A broken thermal fuse usually will.
From your description, I'd say you are definitely going to need a new thermostat, but I doubt if that's the only part you're going to need. You may well need a new thermal fuse and as the control panel got hot, this could have been damaged also.
I wouldn't buy any parts until you've inspected the control panel. You really need a service manual . but they are not usually available free. Failing that you're going to need some test equipment (Voltage & Ohm meters) to find the problem but if you don't know how to use them, it's definitely time to get an engineer.
I wouldn't advise buying any parts until you've investigated thoroughly - unless you can get them cheaply and return them if they aren't needed.
Posted on Oct 18, 2010
I have a Amana Dryer NED7200TW. At the end of any drying cycle the dryer shuts off and then turns on again continuously untill i stop it. It also shows a C and a backward C in the display. Any thoughts?
You might need a new display board (electronic timer ). Seems like the timer will not send the message for the dryer to stop when the cloths are dry
Jul 25, 2012 | Amana NED7200TW Electric Dryer
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Refrigerator section on side by side losing cooling
Here is the Amana website with the manuals which should show you where the defrost timer etc. is located. Witht your model number and manual it will be a lot easer
And yes the defrost timer thermostat and heater are the most likely problem.
Do not let this keep running and running or you may lose your compressor too which means a lot more expense than now.
May 09, 2009 | Amana Refrigerators
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Dryers Logo
74 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
