This bunn coffee maker only brews half a pot what do u think is the problem. it is a 2 warmer on top and burnner on bottom. think model # is f15 of f20
  • 25 Answers
Be sure there is no water in it. put two pots of water in it. It should fill up the pot then. next time just ad one pot of water. and it should work right.It keeps some reserve water in the heated part.
Posted on Dec 06, 2008
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
My bunn makes great coffee, but after 10 min in the cup it is luke warm. Could the initial temperture be set too low?
If by meaning the coffee pot, the bottom warmer maybe loose and dropped inside the machine.Normal brew temp is 195 degrees out of tank.There also may be problem with the hi-limit ,t-stat or element.
Dec 24, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
How do I get the BUNN VPR coffee maker to brew a pot of coffee? There are two switches; one for the lower, and one for the upper warmer. Do I first have to fill the tank ALL the way before it brews? Please...
This brewer has a 2 1/2 pot reservoir. You should NOT plug in the brewer before the reservoir has been topped off. Pour 3 pots (one at a time, every minute or so) through the screen with a pot under the filter basket. Wait until the water flows from the basket and only then is it safe to plug in the brewer. The reservoir holds HOT water until you are ready to brew and then, by pouring in a pot of cold water, you will be able to brew.
Sep 15, 2010 | Bunn VPR Coffee Maker
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
No setup to it. If it is a pourover, add 3 pots of waterto the pour in funnel at the top. keep a pot under the brew funnel, The tank will hold about 2 and a half pots of water. From then on what you pour in is what will come out. If you have an automatic model, it would require a water line hook up and after 2 cycles water will frow from the brew funnel after that, let the machine heat up for 20 minutes and brew coffee like you would at home.
Sep 08, 2010 | Bunn VPR Coffee Maker
Change gaskets on BUNN model CWT15-APS
  • Brews 3.8 to 7.5 gallons (14.4 to 28.4 litres) of perfect coffee per hour.
  • Large 200 oz. (5.9 litres) tank provides back-to-back brewing capacity.
  • Adjusts automatically to varying water pressure.
  • For high lime areas, BrewLOGIC® technology calculates flow rate and adjusts brew time to maintain consistent pot levels.
  • BrewWIZARD® technology incorporates simplified programming with a LCD display.
  • Quickerinstall saves up to 30 minutes. Pot level, cold brew lock-out and tanktemperature set easily from advanced touch pad on front of machine.
  • Electronic diagnostics and built in tank drain make service easier.
  • Ensures coffee brew quality with cold brew lock out capability.
  • Brew into decanters.
  • SplashGard® funnel deflects hot liquids away from the hand.
  • Coffee extraction controlled with pre-infusion or pulse brew and digital temperature control.
  • Automatic warmer shut-off.
Jan 13, 2010 | Bunn CWT 15-APS Coffee Maker
Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Feb 05, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn omatic model F20 doesn't stop dripping
Check out:
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
Oct 02, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
your tank is leaking
Please Follow LINK for parts etc
Jun 12, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
