Question about Sunbeam 5891 Bread Maker
Black goo type liquid oozing from under dough hook when done.
At end of dough cycle I always notice this black gooey liquid under dough hook and it gets on my dough as well. I am wondering if it is some type of oil from breadmaker's motor. I am positive it is not any part of the ingredients and another breadmaker of mine doesn't do this. I am afraid to continue using it and may request a replacement .
  • jimmyant Dec 30, 2008
    Same problem. I believe these are one of the flaws of this machine.
    Champion:
  • 204 Answers
Sounds to me like your seal is bad and you need a new bread pan, which includes the seal. Call phone no. in your manual to get the part you need.
Posted on Jan 11, 2009
Brother E2000 sewing machine, bobbin winder not working. took back off machine, found a "gooey" black substance on the winder shaft, removed and replaced with a "O Rubber Ring", still not working, tri
Gooey black substance was lubricant or grease. Can you really fix this yourself? Let the professionals make the repairs. These companies won't sell parts to you on a retail level. Un Certified repairs can make the machine unsafe to use. Please let a Professional repair the machine.
Happy New Year,
Kelly
Embroidery Services
San Diego, CA
Dec 19, 2014 | Brother Sewing Machines
Despite using less washing liquid than recommended i am still getting quite a lot of suds left at the end of the cycle and dark clothes have noticeable white patches on them from the liquid not having...
Hi.
Here few tips:
Check the type of detergent used. Try changing detergent.
Open the drain filter cap and check for blockage. Clean the filter. Access is in front at the bottom.
Check the drain hose at the back. If height setting is incorrect water with flow back inside the appliance creating the problem.
Access the pressure switch and clean the pressure hose connected to the switch. A defective pressure switch may result in under-filling, leaving more detergent than normal at the end of the cycle.
Regards.
Ginko
Sep 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hello. I just purchased my Kitchen Aid Professional 550 HD last Sunday from Costco. I've used it four times and tonight we noticed that the two thin rings (one black) just above the beater shaft are out...
What I think you are describing is the snap ring (black) which you cannot move and the washer controlling the up thrust of the mixer. The black snap ring is usually a tight fit into the groove on the shaft and shouldn't move. The washer right above it is required to be there enabling the mixer to used with a spiral dough hook. The spiral dough hooks cause upwards pressure on the gear train that does not exist using a c-type dough hook. I think you mixer is fine............leave it alone, that's the way it was designed.
Dec 31, 2010 | KitchenAid KP2671 Professional 6 Series...
Paint from beater bar or pan melting into dough
If the dark streaks are of a liquid nature, then it is the lubrication (grease/oil) from the sealed bearing in the bottom of the dough pan. The seal is broken and oozing out the lube. If it is a solid nature, then it could be the Teflon coating in the pan. Hope this helps...Hank
Feb 09, 2010 | Kitchen Appliances - Others
Water is my refrigerator crispers and meat drawer
I dont know what the book is saying to do nor what refrigerator it is, but in my case the reason for collecting water is that the drain gets stuck with some nasty goo.
This drain so located in the back of the refrigerator and is used to lead away water condensing on the cooling element.
Take a long stiff wire and push it through or make a hook and try to pull the goo out (this is really gooey stuff but it rather does not stink).
May 31, 2009 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
The machine bogs down when mixing the dough for bread
You should be using a dough Hook not paddle I have a Kitchenaid stand mixer and it uses a hook for dough paddles offer too much resistance for dough.
Apr 02, 2017 | Black & Decker B2000 Bread Maker
Diaphramg switch is oozing black liquid, is this a problem?
there should be no fluids comming out,, you may just want to change the pump,,
Jan 05, 2009 | Select Products SP33D Barnes Diaphragm...
Sunbeam 5891 Bread Maker Logo
365 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
