Hi guys, im using a intel dq35mp motherboard with a q6600 2.4ghz core 2 quad processor , with 8gb ddr2 ram (4x 2gb) and 4x 500gb hdd + 1x 1Tb hdd, my graphics card is a 1gb forsa gt220 128bit card. im using a 550watts power supply. i want to overclock my system for it to run much more faster, is that possible. i also want to boost up my boot up speed. ive done a bios update and dat stil doesnt help.pls assist ,so i can get the best out of my system . pls reply to [email protected]
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system hope it helps
SOURCE: i always have failure to boot and have beep
1-Does your computer show any sign of response after power button press? 1. No POST 1.1 Please clear CMOS to have a try (refer to motherboard manual for details) 1.2 If the problem still persists, please contact your retailer for a check 2. There is error message during POST: BIOS ROM checksum error. Detecting floppy drive A media... Insert system disk and press enter 2.1 If the support CD supplied with motherboard is available 2.1.1 Please restart system and put support CD into optical drive, then the system will recover BIOS automatically using CrashFree utility 2.2 If the support CD supplied with motherboard is not available 2.2.1 Prepare a formated floppy disk, then unzip the BIOS file downloaded from ASUS website into the floppy disk. 2.2.2 Please restart system and insert the floppy disk into floppy drive, then the system will recover BIOS automatically using CrashFree utility
2-Is your power cable properly connected and have main power switched on both your power supply unit and the wall plug?
3-Is the 20/24-pin ATX power connector has been connected between your motherboard and power supply?
4-Can The standby power LED (Green blue) light up
continuously after the mains power is connected? (Note: Both flashing
and off are no good here)
Fix 1
(1) Isolate The power going into your system (
i.e. connect your system to the wall plug directly, without sharing the
power with any other devices via power extension cable.)
(2) Check if
the power supply and power cable functions correctly, and have the
input of your power supply set to the correct position (either 100/110V
or 220/240V, depending on your country)
(3) Please try replacing your power supply.
Fix 2
2.3 If it is not helpful after the troubleshooting as the steps 2.1 or 2.2, please clear CMOS( referring to the manual introduction)
Fix 3
Please try the latest BIOS. I recommend you to use AFUDOS to update BIOS. You need to unzip it to get the ROM file.
You should use the command as follows:
AFUDOS /i[biosname]
or, afudos /i A:\BIOSNAME.rom(if the BIOS file is in the floppy disk)
You
can store your BIOS into a floppy disk or a hard disk with FAT format.
Then, you will be able to use AFUDOS to access the BIOS ROM file.
If
it is not convenient for you to use DOS and AFUDOS, you can try to use
EZ Flash. You can save the BIOS file into a flash disk then boot the
system and enter BIOS, then you can update your BIOS by EZ Flash which
is in the BIOS Tools page. Please load the default settings in BIOS
after you have succeeded updating BIOS.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
All other Brand Memory-- Desktop Memory --Abit Desktop MemoryAcer Desktop MemoryAdastra Systems Desktop MemoryAdvantech Desktop MemoryAlbatron Desktop MemoryAlienware Desktop MemoryALR Desktop MemoryAmptron Desktop MemoryAOpen Components Desktop MemoryApple Desktop MemoryAPS Desktop MemoryARM Desktop MemoryAST Desktop MemoryASUS Desktop MemoryAT&T/NCR Desktop MemoryAxil Computer Desktop MemoryBiostar Desktop MemoryBroadax Systems Desktop MemoryCanon Desktop MemoryChemUSA Desktop MemoryClevo Desktop MemoryCompaq Desktop MemoryCompuadd Desktop MemoryCTX Desktop MemoryData General Desktop MemoryDell Desktop MemoryDigital Desktop MemoryECS Elitegroup Computer Desktop MemoryeMachines Desktop MemoryEpox Desktop MemoryEpson Desktop MemoryErgo Desktop MemoryEverex Desktop MemoryFIC Desktop MemoryFoxconn Desktop MemoryFujitsu Desktop MemoryGateway Desktop MemoryGigabyte Technology Desktop MemoryHAL Desktop MemoryHewlett-Packard Desktop MemoryHitachi Desktop MemoryIBM Desktop MemoryIntel Desktop MemoryIntergraph Desktop MemoryIwill Desktop MemoryJetway Desktop MemoryMAXDATA Desktop MemoryMicron Desktop MemoryMicrostar Int. Desktop MemoryMitsubishi Desktop MemoryMonorail Desktop MemoryMotorola Desktop MemoryNCD Desktop MemoryNEC Desktop MemoryOlivetti Desktop MemoryPackard Bell Desktop MemoryPolywell Desktop MemoryPower Computing Desktop MemoryRadius Desktop MemoryShuttle Desktop MemorySiemens Nixdorf Desktop MemorySilicon Graphics Desktop MemorySoltek Desktop MemorySonBook Desktop MemorySony Desktop MemorySoyo Desktop MemorySun Desktop MemorySuperMicro Desktop MemoryTatung Desktop MemoryTektronix Desktop MemoryTiny Computers Desktop MemoryToshiba Desktop MemoryTyan Desktop MemoryUMAX Desktop MemoryUnisys Desktop MemoryVPR Matrix Desktop MemoryWinBook Desktop MemoryZenith Desktop Memory-- Laptop Memory --Acer Laptop MemoryA-Com Laptop MemoryAlienware Laptop MemoryAltima Laptop MemoryAMS Tech Laptop MemoryAOpen Components Laptop MemoryApple Laptop MemoryAqcess Technologies Laptop MemoryAquiline Laptop MemoryARM Laptop MemoryAspen Laptop MemoryAST Laptop MemoryASUS Laptop MemoryAT&T/NCR Laptop MemoryAustin Laptop MemoryAveratec Laptop MemoryBroadax Systems Laptop MemoryCanon Laptop MemoryChaintech Laptop MemoryChaplet Laptop MemoryChemUSA LaptopsMemoryChicony Laptop MemoryClevo Laptop MemoryCommax LaptopsMemorydeCompaq Laptop MemoryCompuadd Laptop MemoryCTX Laptop MemoryDaewoo Laptop MemoryDell Laptop MemoryDigital Laptop MemoryECS Elitegroup Computer Laptop MemoryeMachines Laptop MemoryEPS Laptop MemoryEpson Laptop MemoryErgo Laptop MemoryEverex Laptop MemoryFIC Laptop MemoryFOSA Laptop MemoryFujitsu Laptop MemoryGateway Laptop MemoryGigabyte Technology Laptop MemoryGRiD Laptop MemoryHewlett-Packard Laptop MemoryHitachi Laptop MemoryHyperData LaptopsMemoryy UpgradeHyundai Laptop MemoryIBM Laptop MemoryItronix Laptop MemoryJetta Laptop MemoryJVC Laptop MemoryKapok Laptop MemoryKDS Laptop MemoryKeyData Laptop MemoryKiwi Laptop MemoryMAG Laptop MemoryMagitronic Laptop MemoryMAXDATA Laptop MemoryMaxtech Laptop MemoryMicron Laptop MemoryMicrostar Int. Laptop MemoryMitac Laptop MemoryMPC Laptop MemoryNEC Laptop MemoryOlivetti Laptop MemoryPackard Bell Laptop MemoryPanasonic Laptop MemoryPolywell Laptop MemoryPower Computing Laptop MemoryProStar Laptop MemorySager Midern Laptop MemorySamsung Laptop MemorySceptre Laptop MemorySharp Laptop MemorySiemens Nixdorf Laptop MemorySony Laptop MemorySotec Laptop MemorySwan Laptop MemoryTadpole Laptop MemoryTechmedia Laptop MemoryTexas Instruments Laptop MemoryTiny Computers Laptop MemoryToshiba Laptop MemoryTwinhead Laptop MemoryUMAX Laptop MemoryUnisys Laptop MemoryViewsonic Laptop MemoryVPR Matrix Laptop MemoryWedge Laptop MemoryWinBook Laptop MemoryZenith Laptop MemoryZeos Laptop Memory-- MotherBoard Memory --Abit Motherboard MemoryAdastra Systems Motherboard MemoryAdvantech Motherboard MemoryAlbatron Motherboard MemoryAMI Motherboard MemoryAmptron Motherboard MemoryAntec Motherboard MemoryAOpen Components Motherboard MemoryASRock Motherboard MemoryASUS Motherboard MemoryBiostar Motherboard MemoryChaintech Motherboard MemoryDFI Motherboard MemoryDigital Motherboard MemoryECS Elitegroup Computer Motherboard MemoryEpox Motherboard MemoryFIC Motherboard MemoryFoxconn Motherboard MemoryFujitsu Motherboard MemoryGigabyte Technology Motherboard MemoryIntel Motherboard MemoryITOX Motherboard MemoryIwill Motherboard MemoryJetway Motherboard MemoryLanner Motherboard MemoryLegend QDI Motherboard MemoryMatsonic Motherboard MemoryMicrostar Int. Motherboard MemoryMitac Motherboard MemoryPC Chips Motherboard MemoryPCWare Int'l Motherboard MemoryPine Technology Motherboard MemoryQDI Motherboard MemorySceptre Motherboard MemoryShuttle Motherboard MemorySoltek Motherboard MemorySoyo Motherboard MemorySun Motherboard MemorySuperMicro Motherboard MemoryTyan Motherboard MemoryVia Technologies Motherboard MemoryXFX Motherboard Memory
RAM Upgrade for Intel DQ35MP Motherboards
DQ35MP RAM Specifications
Standard Memory
0 MB (removable)
Maximum Memory
8.0 GB
Memory Expansion
4 sockets
Memory Comments
PC2-5300/6400 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2.
CPU Type
Intel Celeron D or Intel Pentium 4 or Intel Pentium D or Intel Core 2 Duo or Intel Core 2 Quad
Model Comments
800/1066/1333MHz FSB, Intel Q35 Express Chipset, microATX Form Factor
Upgrading RAM on your Intel DQ35MP Motherboards is easy, we carry compatible RAM Upgrade for Intel DQ35MP Motherboards, the Intel DQ35MP Motherboards takes the PC2-5300/6400 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your Intel DQ35MP Motherboards to up to a maximum of 8.0 GB RAM, the Motherboards has 4 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for Intel DQ35MP Motherboards.
Memory Size Chip Description Part Number Price OEM Part # 512MB Module 512MB-667MHz DDR2-667 PC2-5300, 240p DIMM, 1.8v $14.95 In Stock 1GB Module 1024MB-667MHz DDR2-667 PC2-5300, 240p DIMM, 1.8v $24.95 In Stock 2GB Module 2048MB-667MHz DDR2-667 PC2-5300, 240p DIMM, 1.8v $39.95 In Stock 512MB Module 512MB-800MHz DDR2-800 PC2-6400, 240p DIMM, 1.8v $24.95 In Stock 1GB Module 1024MB-800MHz DDR2-800 PC2-6400, 240p DIMM, 1.8v $24.95 In Stock 2GB Module 2048MB-800MHz DDR2-800 PC2-6400, 240p DIMM, 1.8v $39.95 In Stock
MemoryStock Guarantee
