Question about Westinghouse DPF-0702 Digital Picture Frame, Digital Photo Viewer
SD card not recognized
I've inserted SD card into photo viewer, powered the frame on and navigated to the "Select Card" screen. SD/MMC is listed as an option, but it is not highlighted nor can I select it as an option. Please help. I've inserted 2 SD cards and neither will work.
This is a brand new out of the box frame.
Thanks!
    Sergeant:
  • 488 Answers
Make sure the SD card switch is on/open if the problem continues and it is still in warranty return it for a replacement or repair.
Posted on Dec 03, 2017
3 Suggested Answers
SOURCE: Westinghouse DPF-01411 Digital Photo Frame
Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
Posted on May 04, 2009
Tildenator00
  • 47 Answers
SOURCE: Westinghouse DPF-0802 does not display all photos on my SD card
You need to download them onto the frame
Posted on Jan 21, 2010
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
Can i download pictures from my aspire 6920g to a sd memory card
1. open Windows Explorer
2. push the sd card into the sd card reader with its contact side down until it is flush
3. sd card is detected and displayed as a drive called SD/MMC (N:) where N is its drive letter
4. clicking on the SD/MMC drive will list any folders that are in it
5. with SD/MMC high-lighted, click on File and on the drop-down list, hover cursor over New
6. on the New list that opens, click on Folder to create a new folder on the SD/MMC drive
7. right click on the new folder and from the drop-down list click on Rename
8. rename the folder appropriate to the photos you want to download to the SD/MMC drive
9. navigate to the photos and high-light using shift+click for a block or ctrl+click for individual
10. with cursor over high-lighting, hold down right click and drag to new folder and release
11. select from the pop-up list that appears on release to either Copy Here or Move Here
12. repeat from 9 for more photo downloading and when done do an eject before removing ....
13. for Windows XP, click on the Safely Remove Hardware icon at the right side of the Taskbar
14. for Windows 7, can do same as XP or just right click SD/MMC and select eject from the list
15. **WARNING** failing to do an eject or Safely Remove Hardware can result in corruption!!!
16. once message appears that media can be safely removed, push the card in until it clicks
17. once click is heard, stop pushing and it will pop out sufficiently to be grabbed & pulled out
Apr 30, 2011 | Acer Aspire 6920 Notebook PC
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
Jul 26, 2010 | Kodak EasyShare C315 Digital Camera
Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Westinghouse DPF-0702 Digital Picture Frame, Digital Photo Viewer Logo
113 people viewed this question
Top Westinghouse Photography Experts
teddyboy
Tom Chichester
Tom Lahart
Level 1 Expert
Are you a Westinghouse Photography Expert? Answer questions, earn points and help others
