Question about GE JVM1790SK Convection/Microwave Oven
My GE JVM1790SK
Look like the interior light burnout and the fan kick in at the same time whenever I latch the door in, When the door open, everything is ok other than that , everything seem to be working, microwave/ Convection oven.. Does anyone know how I can remove the interior bulb? interior NOT under the microwave
  • Anonymous Mar 28, 2014
    Everything elxe seems to be ok
  • GE Master
  • 9,098 Answers
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 You may have a bad door switch. We also have a file on door switches at our site.
Posted on Feb 19, 2007
Ge PT 916 wall oven interior light will not go out convection fan does not work I'm thinking it thinks the door is open but I don't see any switch to activate when door is closed any thoughts please
the light will go on and the fan will work regardless of the door position
suggest that you get an electrician in to check the oven electrics
Nov 17, 2015 | GE Microwave Ovens
Jvm1790sk fan comes on when i OPEN the door
Pretty sure its the door interlock switches.
you might need a service call from the authorized rep.... sorry.
Oct 14, 2013 | GE JVM1790SK Convection/Microwave Oven
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
My control panel will set for time other functions will work and and light and fan time will reset but will not turn. on noticed that the door sags and the upper prong that keeps it closed is broken off....
due to the fact that micowaves produce extreme amounts of high range rayons the units are constructed with several safety features one of the main ones being twin micro switches built into the door latching. when the door is open it sends a signal to the microwave to stop working so unless both latches are in place and strike the switches the unit will think the door is open and not respont to cook. you will have to have the door latch replaced parts are available form www.kenmore.com as well as ebay and as close as your local reapir shop.
best of luck
please take the time to rank this reply
thank you and merry christmas
Dec 07, 2010 | Kenmore 80599 Microwave Oven
The automatic fan will not shut off. I shut the door and there seemed to be a spark and then the fan will not shut off unless I open the door. It sounds like it is always running.
I wonder if you've had trouble with the cooktop lights recently?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 30, 2010 | GE JVM1790SK Convection/Microwave Oven
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a GE jvm1790 microwave that when its pluged in, the magnatron fan runs with the interior light is on constantly. I can't start either the microwave or convection. Everything stops when the door is...
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Nov 06, 2009 | GE JVM1790SK Convection/Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Advantium 120 Keeps running
I've got this problem also.
The interior light on the oven died. We replaced it. Since replacing it the light stays on and the turn table turns.
Looking at the diagram, the "main relay" is what powers both. My guess is that it's stuck in the "on" position. Solution will be replace the relay.
Long term fix may be bigger relay.
Jan 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
GE JVM1790SK Convection/Microwave Oven Logo
358 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
