Question about Philips 50P8341 50" Rear Projection Television
Philips mod. # 60PP920217F
My niece kept pushing the power button on/off and now it won't turn on. When power button is pushed it lights up red and stays that way and a chirping sound comes from the rear but still no picture. Any ideas would be great.
    Genius:
  • 1,139 Answers
Hello bradahman,
The chirping sound is either a shorted Horizontal Output Transistor / Power FET (whichever one is used in this case) or the IHVT (Flyback Transformer) has developed a short in its windings. In ether case both components will have to be replaced. I would suggest you have a qualified TV technician come over and troubleshoot the problem and give you an estimate on the repair.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 09, 2008
When you turn tv on it just makes a clicking sound its a phillips model 60pp920217f
If the front panel indicator lights, you are getting power to your TV. The symptom you describe suggests the power supply has failed
Jan 04, 2013 | Philips TV Tuner Video Capture PCI Card -...
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
I need the code for a philips tv
1. turn on your Phillps T.V. 2. Press and hold the setup button (underneath the power button) until the red light stays on. Release the button 3. Push the "TV" button on the remote once (red light sohuld go off) Press the on/off button slowly as long as it takes until your T.V. turns off. 5. Push Enter once to save the code.
Jun 24, 2011 | GE JASRM24912 Remote Control
PS3 won't turn on. When I push the power button
Sounds like your system has a failure in it, that needs professional assistance. If you want your data saved you should try a place called www.videogame911.com. They do fast repairs and can save your data.
Jun 11, 2011 | Sony Video Game Consoles & Games
Mod ler4634pqo push button to start and nothing--i traced power all the way to push button and it is fine ?????
Did you check the HI Limit on the back where the heating elemnts is?There is a little red button on click disk where the heating elements is. Power has to go throught there before it gets to the push button.
Jan 29, 2011 | Whirlpool Dryers
Rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
Aug 22, 2008 | Televison & Video
Codes for Philips 4 Device Universal Remote, Model US2-PM435S
Try this:
turn on the tv manually,then push and hold CODE SEARCH button until the red light stand still now release the button push and release the device button TV after that you got to push and release the ON/OFF button until the tv goes off stop.Now push the enter button to memorize the code check if the tv turn on with the remote.
You have to get some patience because you need to push the power button between 1 to 110 times.Good luck
Apr 17, 2008 | Philips 5-Device Universal Learning Remote...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Philips 60pp920217f Blinking Power Light
Call a technician. If fixed it is worth it for ~$200.
Jun 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
