Question about Honeywell Programmable Thermostat Heater
Blower cycling problem
Installed a honeywell programmable thermostat on a Tempstar dc90 furnace. When not calling for heat the blower cycles on and off constantly every 30 seconds
    Genius:
  • 1,199 Answers
Sounds like a relay problem!
Posted on Dec 08, 2008
Tempstar DC90 pilot light or burner keeps going out. The furnace will run continuously. Even if I turn heat off at the thermostat. I have to kill power at the panel box to get it to shut off. Then I've...
The reset button near the ignitor is a high temperature limit safety switch. When the furnace gets too hot and the manual reset limit switch is tripped, it most likely goes into a 'safe' mode where the gas control is locked out electronically and the blower is made to run continuously to rid the heat exchanger of the excessive heat. This will continue until the reset is pushed and the power is cycled off. It will remain an endless cycle unless the reason for the overtemperature condition is not corrected.
Your furnace 'temperature rise' is getting too high due to a lack of air across the heat exchanger for whatever reason. Some of those reasons could be a restricted air filter or a blower motor that's cycling improperly on its internal winding thermostat. You could also have a dirty air conditioner 'A' coil (evaporator) on top of the furnace restricting the air flow. Nevertheless, you are going to have to have it serviced by a reputable service company's technician to correct what's wrong.
Nov 13, 2014 | Heating & Cooling
After heating cycle, the furnace fan doesn't shut off
Be sure the continues run switch is not turned on at the thermostat
Nov 26, 2013 | Honeywell Programmable Thermostat Heater
Tempstar DC90 willnot shut off
I can't stand the tempstar smart valve! Now I'm not sure what a dc90, but if you have a gas fire residential furnace I know what it is. The smart valve controls gas and flame proving only. The blower issue is probably one of the high temp safeties that has stuck. During a call for heat, your system verifies that all safeties are closed. If this sequence is not correct, then the unit assumes that the unit has overheated due to a high temperature safety issue, and brings the blower on to cool it down, normally for 90secs. Also if the unit is calling for heat when the power is turned off, still calling for heat when power is turned back on(like you said by throwing the switch), this will also bring the blower on for 90sec, then blower will/should turn off, and the heat cycle will start. So if your tstat is calling for heat(heat on and set temp higher than accrual temp), and you turn off power then turn power(main voltage) back on, this will bring blower on for 90secs. Now, the burners staying on is a different issue. I've not seen that in 15 yrs of service on a smart valve. There is probably 24volts feeding the "W" circuit, for some reason. On the control board there is a terminal block with R W G Y C. The W is your heat. This W receives a 24v signal from your tstat. Turn off power, remove W from the board, then turn power back on. If no heat then you've isolated your problem to the control wire coming from your tstat, or the tstat itself. If it continues to heat with W disconnected then its something in the furnace, circuit board? Hope this helps!
Mar 04, 2017 | Null Heating & Cooling
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
Furnace comes on after two or three minutes off.furnace seems to run to often.
If the blower only runs it is likely due to a dirty filter or too many vents blocked or closed. Sencondly if the furnace runs more than you remember before installing the new thermostat look for an adjustment (sometimes called heat anticipation) and select fewer cycles per hour, this will allow a little lower temperature before it comes on hence fewer cycles per hour.
Mar 03, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programmable thermostat with a York high efficiency furnace. To turn the heat on, the thermostat "clicks" and cycles the furnace through startup (warm the fire starter, turn on gas,...
Well, it is a computer, and they all glitch, now & then, you say it clears with a power off, and thus resets it, It maybe a thermostat, flaking out, they do that, but the 6'o'clock, thing being the "Or" that sets it apart, I wonder if it isn't just a faulty control unit, as two together is too many, for a single cause, now, it sort of points there, but also, may sound silly but first, of there is any, Check your backup battery..
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell ct3200 with a trane xl 80 furnace. it will cycle on to the right temp, go off and cycle the furnace back on 30 seconds later. Is that normal? It is 32 degrees outside, set at 68
Hi, check page 22 in your manual, it says "Adjust the screws on the back of the thermostat as instructed on page 7." Your furnace is a 80% efficiency but is also a high efficiency 2 stage heating system so try adjusting screws A and B both ways and see which gives you the correct cycling.
Your manual is here:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat TH6110D1021. Blower comes on
Hi, You are right, fan is on a time delay in the heating cycle, and after burners fire that is when this delay comes into play. You have a preset factory temperature that determines the cycle on time for the fan, and the off time after the burners shut down also. This will not be in the thermostat, but in the fan/limit control the is mounted on the face of the furnace, with a probe inserted into the fire box.Depending on how old or new this unit is, will depend on the type control you have.It may be just a high limit switch, or the 1st I mentioned.If so, It rotates in the burner as the temperature rises, to turn the fan on and off.Disconnect power, remove cover, and 2 screws.Slowly remove the control and gently clean the probe. Turn the dial if this one has it and you will be able to hear it click. This click is contacts closing to start fan operation.Reinsert and try again. If problem continues, you will have to replace it.They do tend to stick closed/on, in the heat cycle from time to time and a cleaning sometimes will solve this problem. Not knowing how old this furnace is and type, make it difficult to give you a correct diagnosis, so check this fan control as I have explained, and if your system is of a different type, please let me no so I can correct this problem. Sincerely,
Shastalaker7
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
New thermostat honeywell RTH7400 cycles oil furnace every 10 min.
rth7400 maintains a 1 degree differential in temp so 10 minute cycles are not unusual.
Vinnie
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Dec 13, 2008 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
235 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
