Question about Dell E173FP 17" LCD Monitor
Dell Latitude LCD screen is dark, but computer is still working.
I have a Dell Latitude D505 that suddenly developed a problem with the LCD screen. I turn it on and can very faintly see that it is booting up, but it is so faint that I can't use the mouse or keys to login or use it. I have plugged a monitor into it and can use it just fine this way, so there is nothing wrong with the computer itself. Since I can see the screen very faintly I'm thinking tht the backlight must be working in some capacity, but is there a way to adjust the light? What could be wrong? Can anyone help?
    Scholar:
  • 135 Answers
It sounds like the backlight has burned out. The faint light you are seeing is ambient light in your room being reflected through the LCD. Try it in a perfectly dark room and see if you can see anything on the screen. The following page should give you a sense of what is involved in replacing a backlight: http://home.comcast.net/~stonent/screenfix.htm If you aren't comfortable taking things like this apart, I would recommend finding a local repair shop to replace the backlight.
Posted on Feb 18, 2007
SOURCE:
No backlight showing
If the LCD has no backlight and the display works on an external monitor, the a LCD replacement is the likely answer.
You can get LCD and inverter for about $60
http://shop.ebay.com/i.html?_nkw=Latitude+D505+LCD+inverter&_sacat=0&_odkw=Latitude+D505+LCD&_osacat=0&_trksid=p3286.c0.m270.l1313
Sep 26, 2010 | Dell Latitude D505 Notebook
Display is very dark and can barely be viewed. Brightness controls don't do anything. Any suggestions? It is a Dell latitude 505.
Sounds like the back light has gone.
You may be lucky and you just have a loose connection, its worth taking the front off the screen surround and re-seating all conectors.
If it is the backlight, you can get a replacement quite cheap (£10)
I found this site
http://www.keyboard4laptop.com/ccfl-backlight-lamp-dell-latitude-d500-d505-p-4580.html?currency=GBP&language=en
Jul 11, 2010 | Dell Latitude D505 Notebook
Screen is dark
try connecting a external monitor and see still its dark on the video or else then the LCD needs replaced
Jan 12, 2010 | Dell Latitude D600 Notebook
My dell 505 has lost the screen, i can faintly see something on it, but not sure what happened
sounds like the bulbs gone, try brightening it up. if no joy you can buy these screens on ebay for a very cheap price just search you make and screen. dell latitude d505 lcd display, should find oen there. hope this helps
Dec 03, 2009 | Dell Latitude D505 Notebook
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
Vertical red line in display
I had a similar problem with a flat screen lcd for my desktop comp, and it turned out that I needed a new screen if i wanted to get rid of it, but it doesnt really cause much of a problem, so i didnt bother replacing it. If your laptop is still under warranty, (i dont know how long your warranty lasts) I'd look into getting it replaced if it really bothers you. But yes, its definitly the screen.
Aug 08, 2008 | Dell Latitude D505 Notebook
Connecting to internet
check your phone socket. Check your connection settings and passwords check that your router is set correctly
Feb 21, 2008 | Dell Latitude D505 Notebook
Backlight of LCD turns off
For latitude systems they have this ambient light sensor. it basically adjusts the brightness of the screen depening on room lighting. try to go to bios by hitting F2 on the dell logo. go to video and try to look for ambient light sensor. however, im not sure if your computer has that feature I have a second option for you though. based on the troubleshooting you've done, it seems that the video back lighting is affected by movement. it would be a good try to reseat the LCD cable. you can use this link to guide you in fixing the computer : http://support.dell.com/support/edocs/systems/latd505/sm/keyboard.htm
all you need to do is to take out the keyboard with 2 screw holding it in place. the LCD cable should then be accessible. it a thick cable that coming out of the Left hinge.
Hope this helps.
thanks.
Dec 24, 2007 | Dell Latitude D505 Notebook
Black Spots on LCD for Latitude D505
If you?re positive that the black spots aren?t dirt or scratches on the outside of your screen you are probably dealing with dead screen pixels. Short of replacing the LCD screen there is no way to repair them.
Dec 13, 2006 | Dell Latitude D505 Notebook
Dell E173FP 17" LCD Monitor Logo
264 people viewed this question
Clive
Clive
Alun Cox
