Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Cannot download executable files.
I am running vista home premium wiyh sp 1.
I cannot download executable files and then run them. At the end of the download I get a message that windows has determined that the downloaded file is a security threat and the file will be closed. The message also gives me a link to windows mail, but I have not found that trying to change any settings has helped at all. I have also disabled zone alarm pro and symantec 360 version 2 without any help. I don't think my computer is infected. Can you help me?
    Sergeant:
    Novelist:
  • 192 Answers
Ok, the first thing to check is whether or not the system is infected.
Goto http://onecare.live.com/site/en-gb/default.htm and choose the Beta edition for Vista.
Follow the on-screen instructions and let this run (it will take a while, so you may want to put a film on). Keep an eye on it, as it may ask you for some actions. If nothing bad is found or after cleaning this still happens then please follow these next steps.
Did you install Service Pack 1 via Windows Update?
This has caused problems with alot of programs and systems, as it doesn't always install all the bits that your system needs. You need to uninstall the Service Pack. Please use this link to find out how:
http://support.microsoft.com/kb/948537/en-us
Now the thing is, you really need the Service Pack. Once you have uninstalled it and restarted the computer, you need to ignore any Windows Update/Automatic Update messages that may pop up for the moment.
You need to download and install the complete Service Pack 1. Just click on this link and press download: http://www.microsoft.com/downloads/details.aspx?FamilyID=b0c7136d-5ebb-413b-89c9-cb3d06d12674&DisplayLang=en
As this is the complete Five Language pack, 434MB, it may take awhile depending on your internet speed. I would recommend this anyway, as it would sort out any other bugs/problems that you may not have noticed.
Anyway, have fun, and let me know how you get on.
Tim
Posted on Dec 08, 2008
I keep getting an error message saying "windows can not access the specific path or file. you may not have permission to access the item" but I am the administrater
Keep signed in as the administrator and do the following.
  1. click right click the resource icon.
  2. In the menu that pops up select "Run as Administrator".
  3. The Window should execute.
Good Luck!
Feb 17, 2011 | Microsoft Windows Vista Home Premium with...
Vista home premium missing help files
Dont worry if you are missing help files...........just follow these steps...:-
1) get to someother computer which have windows vista premium running. try to find help files in c:/windows directory.
2) Once found copy it into usb and copy those files in your system at the same location from where you have copied them in other computer.
3) Restart system and its done.
Other way is to use vista recovery disk to copy system files ...
Hope it works well for you.........
Dec 24, 2010 | Microsoft Windows Vista Home Premium...
Make it work with VISTA home premium
What version of Windows are you using it on at present, or have you been in the
past? If XP then get the latest versions from:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?
os=228&lc=en&cc=us&lang=en&product=59968&dlc=en
There's a main download and an update.
If you have any HP software that you have tried uninstall it using Remove
Programs and then disconnect the USB cable from the PC end and install the XP
software as follows:
Locate the downloaded file ps804en.exe 1/1 (70.62M) on your computer, Right
Mouse Click on it and select Properties / Compatibility TAB.
On that TAB, check Use Compatibility mode and set it to XP with SP2 and also
check lower down the [x] Run as Administrator and OK your way out.
Do not connect the device until the installation procedure tells you to or
until you get to Finish.
Then repeat the procedure on the downloaded update file ps803mu.exe 1/1
(373.11k) although you can leave the USB cable connected unless it tells you
otherwise.
May 08, 2009 | HP Photosmart s20 Film Scanner
My Type Artist won't run on 64bit Vista
most will have to be run in compatibility mode. movies on cd & dvd probably won't burn to cd (or run at all). they're too old for the manufacturer to post patches for vista support.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/
if the software is already installed on a pc, run the upgrade advisor to get more info on compatibility.
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx?wt_svl=20409a&mg_id=20409b
Feb 22, 2009 | Clickaction My Type Artist (2085346)
Can't run Backup discs. Using Home Premium software and Vista
Questions that I have to ask.
Did you make restore disks when you first bought the Machine or software?
Did you make your backups on the machine you are using?
I normally have to go to a factory reset, and reload programs and saved files. I have had this machine 5 months, I gripe like hell when my old software does not run, after it has updated. Factory settings allow me to run old software.
I am using Windows Vistra Home Predium with Service Pak 1 and Service Pak 2.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
PC email attachments
Instal any download manager on your PC.
Jan 27, 2009 | Microsoft Windows Vista Home Premium with...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
