Question about Panasonic PT-51HX40 51" Rear Projection Television
Panasonic pt-51hx40b i need to remove the top from the bottom so i can bring the unit up a flight of stairs that is narrow
  • joshspencer9 Feb 05, 2009
    where is the convergence board located and how much would it cost?
    Genius:
  • 2,920 Answers
Big screen tvs are not made to come apart that way.the only thing you can do is take the back off it and i dont think thats going to help your situation
Posted on Dec 06, 2008
Panasonic PT-51hx40b projection TV powers off when I try to turn it on
Not sure if the transformer is bad or something on secondary side is pulling the voltage down--if replacing it cured the issue you did good.
If not try to disconnect at source on secondary side to see if with no load the voltage comes up.
Looking for either the xfmr to be bad or something shorted pulling the voltage it creates down.
May 14, 2012 | Panasonic Televison & Video
Panasonic PT-51HX40B turns itself off and has no video, no lights
The buzzing noise that you were earing came from a bad ballast, and because of the bad ballast your lamp must have got out also, and that is were you are getting the burned smel from and also that is why you are no longer geteting any picture either.
So in this case you would have to replace the ballast board and the lamp on your tv set.
Jul 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Apr 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
I have a panasonic rear projection lcd, it has a yellow tint around center of screen. Help
My PT-43LC14 has a yellow tint on 3/4 of the bottom to top. the top 1/4 seems normal. I removed the bulb assembly and it looks OK. Any ideas. Is there anything I can doe myself. and if so what is the p/n I can buy?
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Hello, I have a stacked Whirlpool washer/dryer. (Model # LTE6234DQ1) I wish to move it down a flight of stairs and want to know if this model can be easily 'unstacked' for the move. Thanks for your...
Hi there.
Yes it can.
Access bolts to the feet should be visible from the rear of the unit. Failing that, the top screws of the bottom appliance should undo, and the top appliance (with lid of lower one) should slide back 1" allowing it to be taken off.
Be careful not to damage this lid section in the move, and further removal can restore it back to two appliances again.
If this helps, Please take a moment to rate as Fixya! Thanks.
Jun 17, 2008 | Whirlpool Washing Machines
Check the board first, this it burned?
Jun 03, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-51HX40B convergence issue
Hi.....
Bit of a long shot but have you tried this??
http://oreilly.com/catalog/htheaterhks/chapter/hack12.pdf
Hope it helps!
Richard
Apr 28, 2008 | Televison & Video
Color registration doesn't fit. The Blue is hanging to one side and it's a bit wider
Color registration doesn't fit?? Do you mean that you have a convergence problem and that the colors are not aligning?
That set uses two STK392-010 and all low ohm the feed resistors out front of the amp should be checked for change in ohm value: R7051, 7050, 7049, 7048 all of them are 10 ohms 1/2 watt.
Bill
Nov 26, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
104 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
