Maxtor 80gb external drive bleeps when powered up and not able to access
    Novelist:
  • 171 Answers
This is a well known symptom, it's called the "musical maxtor" symptom.
The bleeping occurs because you damaged your drive, either by dropping it, bumping it, or just from excessive wear and tear. The drive detects this and warns you with the bleeps.
All the data is most likely lost, and you will need to replace the drive.
Posted on Dec 06, 2008
Can I put in my PC Compaq Presario SR 1610NX a Hard drive Maxtor 40GB, 3.5 ? Thanks
Desktop Specs Link Motherboard Specs Link
A. From the first link above, you already have a 80GB 7200rpm hard drive and a combo drive with no further details. you can only use two additional devices one 3.5 inch external and 5.25 inch external bays.
B. Assuming that two devices are already IDE devices, that will leave you two additional IDE and two SATA device.
1. Turn off your computer before plugging any additional device and proceed with cautuion.
2. Add the additional 40GB Maxtor IDE hard drive, you will have to mount the drive into the casing and put some screw to lock or use tool lesslock if its present. (Check the jumper if its a master or slave) if you have configured the 40GB drive as master and you're going to add additional IDE drive you have to put the jumper in slave header.
3. Now put the IDE cable to the hard drive and to the IDE2 of the mother board mount firmly. (you cannot mount the IDE cable if it is in the wrong position)
4. Next the four pin power from the power supply to the hard drive. (you cannot mount the power cable if it is in the wrong position)
5. Power On your computer and press Delete or F2 to access bios, proceed to the option boot priority select your Combo drive as first boot, next your 80GB Hard driver, press F10 save.
6. Power On your computer and check your 40GB hard drive through device manager.
7. Time to add your new hard drive through disk management, so you will be able to see your new drive from your computer. I forgot how WIN XP recognize new hard drives especially the fresh one.
Hopefully this information helps.
Feel free to ask, so I can clarify things.
Thank you for using FixYa.
Sep 05, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Maxtor 3100 80GB External Hardrive clicking/humming sound.
This could be an issue with the circuit board.I am facing a similar problem & shown it for repairing. And facing issue in sourcing the IC. Seagate is giving support for maxtor after it has taken over. Data recovery is possible only if the circuit is working.
Jan 10, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
MY external hard disk maxtor is not detected
Is this a new Maxtor external drive? It came with a CD. Run the utility.
If there is no data on it that you want to save, you can also blow away the partition and format it:
Right-click [My Computer]
[Manage]
[Disk Management]
Find your external Maxtor Disk inthe list and / or graph
Right-click on the disk and select either "Format" or "Delete Partition"
(try format first) Use "NTFS quick format"
If you delete the partition, then "Create Partition" and then format.
You can assign a drive letter or accept whatever it assignes (probably Drive D)
*done*
Sep 30, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
I cant open my external hard drive
The Seagate website should have the installer available for download under their support link. You will have to look up your exact model # and download the package for the operating system you are running. Hope this helps.
Aug 05, 2009 | Seagate 80GB One Touch 4 Mini-maxtor USB...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Need drivers for a Maxtor 80GB Onetouch III Mini edition
I have a Maxtor Ext HD myself. Maxtor has a website. Try www.maxtor.com or Google it and you will find their web site. Then search for your HD and do a search for the download of the drivers needed for your HD
Mar 13, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Drivers for Maxtor Peripherals
These USB external drives doesn't need any drivers at all if you have windows 2000/xp/vista, I suggest you to try some other USB ports if the one you tried doesn't work. Or if you are using an USB hub than try it out without it, and maybe a different or shorter cable could be the solution if it's still not good. If after all this the drive is still wrong try it out on a different PC and see what'll happen.
Dec 29, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
