Question about Canon Cameras
I have a powershot 70 camera. Just recently when it powers up I do not get any display on the screen and it will not take pictures any more. I changed batteries twice and cleaned all contacts with no success. I even changed the memory card. Still no progress. Help?
  • 10,594 Answers
It is problem of defective CCD Imager Sensor in canon A70 camera and this part needs to be replaced.
Canon will replace it free of cost as per announced CCD Imager support scheme.
Click Canon CCD Imager Sensor Advisory for details.
Thank you.
Posted on Dec 06, 2008
Canon G5 Powershot LCD screen is black and will not show images in any setting.
Are you sure the battery is ok? Did you press the button display (bottom right nest to the display) several times? Next, how long did you not use this camera? If it was for long, something inside could be corroded. Did you recently drop the camera? Something more serious could be wrong. I'm not sure you can make any picture, because you don't need the screen to make a picture. You then could look is a proper picture is on the memory card. If the rest of the camera is working ok the viewing must work also. Check is the off button is moving correct. (And not blocked) Resetting could be an option, but you need the display to answer the question. This is in the user manual.
Oct 23, 2013 | Canon PowerShot G5 Digital Camera
My cameras power seems to work but the screen is all pur black ?? what can i do to fix this???
I have canon power shot sd1000 camera. Every thing is o.k. except that recently the screen stays dark in picture mode and when on for taking pictures. pl let me know.
Feb 03, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
Camera's screen is black, but still takes pictures.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, try pressing the DISP button once with the camera turned on.
Dec 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
View screen won't work
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Dec 05, 2009 | Canon PowerShot SD1100 IS Digital Camera
Dark Screen
Your lens can not open the shutter, or CCD is dead. If you kept your camera in your pocket, most likely fine dust got in the lens and ultimetly between the shutter blades and now due to friction they can't open. But if you kept your camera clean, then it is dead CCD. You can have it fixed by replacing the CCD or the entire lens, but in particular this SD1000 camera the main board components can go wrong too. You can sell it "as is" on ebay for $50-70 and buy a working one for 80-90, the difference would be $20-30.
Jul 23, 2009 | Canon PowerShot SD1000 Digital Camera
I dropped my IXUS 70. Display screen has black section.
You have a bad CCD. The CCD is like film, it is what the light hits that actually convert an image to a picture. This is a repair as a rule that is more costly than what your camera may be worth.
Jul 03, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
May 27, 2009 | Canon PowerShot A550 Digital Camera
Lens
You might have switched off the display by mistake, which is used as a power saving option and can be switched on by pressing the display button.
Jun 03, 2008 | Canon PowerShot A510 Digital Camera
Vertical stretchon pictures
This is from what you describe - more the computer dispkay than a camera proble.
How do other images look[not the camera] on the screen?
or the deck top. -Check out this first them come back to the camera images.
Nov 15, 2007 | Canon PowerShot S3 IS Digital Camera
Cameras Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
