Have a Samsung DVD-R136 which will not accept a blank disc. When a blank DVD-RW is inserted the manual tells me that the machine should prompt me to format it. But instead, it just spits the blank discs out. Any help appreciated.
Hello, First be sure your using the correct disc DVD+ or DVD- RW etc.
I would recomend using high quality discs as players/recorders are very picky about cheap media. Try using Imation name brand discs. They read well in most anything. If it has worked fine & then started having this problem I would first check to see if your using the same discs that have always worked with it & if so then you may want to open the unit & clean the laser lens with a cotton swab lightly soaked in rubbing alcohol. Especially if it has been smoked around or is in a dusty environment.
dvd-135 will not load blank discs or pre recorded discs. Blanks are sony dvd-r.
