Question about Casio G''zOne Type S Cellular Phone
My outer face plate on the gz one is scratched up can it be repla
The orange outer shell is scratched up can it be replaced ,the rest of the phone is fine.where would i get the outer plate.it has screws on it and I want to take it off if possible and replace it.thanks
  • 6,487 Answers
Es that can be replace but , but it will be hard for you to find a replacement part for that, it will be better if you take it to casio servcie center and have it replace there....
Posted on Dec 06, 2008
    Genius:
  • 2,920 Answers
Take the phone to the dealer where u got the phone and see if they dont have replacement faceplates.or go online and order one from the company that sells the phone
    Sergeant:
  • 399 Answers
U can try to get at the servicenter of the casio or at radioshack websites if possible.
    Genius:
  • 3,422 Answers
You can buy the face plate from:
http://www.1800mobiles.com/verizon-gzone-boulder-accessories.html
What does plate tectonic theory mean
Plate tectonics is the theory that Earth's outer shell is divided into several plates that glide over the mantle, the rocky inner layer above the core. The plates act like a hard and rigid shell compared to Earth's mantle.
Feb 20, 2015 | Edu-Science (10166) Telescope
Want to remove outer shell from a GE top load washer
Take back panel off. Then there 4 screws on the bottom. All 4 corners
Oct 08, 2012 | Dishwashers
The lights on the front of my nightwatch is not working but the rest is the meter and channels light up and the dimmer works just the backlighting wont whats the problem thanks
  • That Night Watch face plate is AC ran by a converter inside the radio. The LEDS are part of the face plate and sold as one unit. The face plate goes out often on these radios. In short the face plate needs replaced if you want it to light up. The radio's performance will not be effected by this. Cobra can actually switch that out fairly cheap. Cheaper than buying a face plate used on the net.
  • https://www.cobra.com/index.cfm
Regards, Tony
May 20, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Internal screen is broken. Where can I send it to get it repaired?
the out side cover Gz one rock 731 , circle vew has a scrach .I would like to replace it. there is only (2) screws to take a part , the outer cover is holding it together .
THIS THE OUTER PLASTIC TOP FLIP OPEN TO . WERE THE TIME IS VEWED
PLEASE ADVISE
N9GDY@YAHOO.COM Harry Hartmann Wisconsin,54905
Jan 11, 2011 | Casio G'zOne Rock Cell Phone
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
customercare@grilltechs.com
Nov 06, 2010 | Tec Patio II Grill
Removal and installation of 1988 harley sportster clutch
In order to remove the clutch from your bike, you must have a special tool. You'll need H-D #34761 in order to remove the snap ring holding the clutch together.
Disconnect the battery, drain the primary, and remove the primary cover. Once you have the primary cover off, you can remove the nut from the compensator sprocket at the engine end of the primary chain.
Install the H-D 34761 or equivalent tool and compress the clutch spring. Remove the snap ring and then back off on the tool to release the pressure on the clutch spring. Once the pressure has been removed, remove the adjusting screw assembly, the outer clutch spring seats, the clutch spring, the inner clutch spring seat, and the pressure plate.
Then you can disassemble the rest of the clutch. Remove the remove the four friction plates and three drive plates. Then you can remove the spring plate and the remaining plates after that. Remove the snap ring that holds the clutch assembly onto the transmission clutch gear and remove the inner and outer clutch shells, the primary chain, and the engine sprocket as a group.
For this job, I would recommend that you purchase a service manual. It's has pictures that show you what you're dealing with and in this case, a picture is truly worth a thousand words.
Good Luck
Steve
Nov 05, 2010 | Harley Davidson XL Sportster 883...
My screen on my lg kg800 is scratched how can i replace it with a new one
is the actual screen inside scratched or is the outer phone housing screen cover scratched? There is a difference. The actual LCD screen is inside the phone housing and is protected by the phones housing. If the actual LCD screen somehow was scratched it can be replaced very easily and usually inexpensively. Try Ebay for the LCD. If the phones outer clear housing is scratched you can also replace the housing either by purchasing the same phone used and using its housing or some "dummy" phones can be used for there housings also. If the scratch is not really bad I have used rubbing compound to remove fine scratches, good luck!
Sep 03, 2008 | Cell Phones
Replacement of body shell for 7373
well aparently the front clicks off with a screw driver, according to nokia, but i have not tried it yet, so dont blame me if it does not work. about the rest of the phone i have no idea..sorry!!!!
Oct 21, 2007 | Nokia 7373 Cellular Phone
Top plate
What do you mean by the top plate? Do you mean the actual outer shell of the unit itself, or do you mean the platter? Both are available as special order from - www.djproaudio.com and range in price from $40-120
Sep 22, 2007 | Pioneer CDJ-800 Turntable
Casio G''zOne Type S Cellular Phone Logo
253 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Oloyede Monsuru
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
