Question about Video Game Consoles & Games
The power bars cord snapped. How and where can i get it fixed?
  • 171 Answers
The cord "snapped"? The cord is at least 20 gauge copper, how did you manage that?
You should replace the power bar entirely. It is dangerous to use a power bar with a damaged cord, even if you reattach it. It is easier and cheaper to replace it than repair it.
Posted on Dec 06, 2008
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
The push button to open the door does not engage door, so door does not open
in most cases this is due to a snapped of push bar as they are made of plastic its a common fault. if the push bar is not snapped then its lost a plug that holds it in. as the microwave holds a constant 1000 watts of power i always recommend to people to have them fixed by lic techs the repair cost for this fault is around $ 100 if the part is still available
hop this helps please rank advice below
Dec 28, 2010 | Whirlpool GT4175S Microwave Oven
Snap Server does not power up. Replace the power cord, but it still does not respond. Anyone know where I can get a power supply?
Did you fix your Snap Server? I am looking for one for parts (need a 160 GB hard drive out of it for a data recovery job). I will buy it (or one of the 160 GB drives) if you are interested to sell?
Sep 08, 2010 | Snap Appliances 2200 (5325301654) Server
I have checked all three inputs into the wii unit; the power cord, the sensor bar cord, and the rca cords (all three) and I still can't get the wii to come on. The wii power cord shares the same plug as...
The sensor bar cable and the RCA cable can be ignored for this problem. In fact, just disconnect them and go with just the power cable. If you are getting power to your Wii, it will display a green power light on the front when you power it on without the sensor bar or the RCA cable plugged in. (It should also display an orange light when it is off, if it is getting power from the outlet.) Take the Wii into another room with working outlets and plug it in. Attempt to power it on with the power button on the Wii, and with a working Wii remote. If neither will power the Wii on, try borrowing a Wii power cable from a friend, or purchase a replacement. If the new power cable does not fix the problem, see if the Wii is still under warranty and send it in for repair.
Jul 05, 2010 | Nintendo Wii Console
Stihl Farmboss - cord will not move
try taking plug out to see if it turns then.if not take off pull cord assembley to see if something has come loose and jammed flywheel, failing that could possibly have snapped the piston ring and jammed. oh yes one last thing check clutch if you have chain brake on and clutch is jammed obviously wont turn.
Dec 21, 2009 | Garden
My new phone has frozen with a screen of a red bar, green bar, blue bar and white bar. PLease help
Replace it or pay lots of $ to fix. unless its still under warranty, than they can fix or replace it.
Nov 20, 2009 | HTC Snap S522 Cell Phone
The bar in between the handle bars has snapped can
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
I hope this was helpful, DutchTexan
Oct 13, 2009 | Quinny ZAPP Stroller
Power suppy
Seeing how the AC Power Cord Plug Snapped, It probably loosened the pins on the DC Power Jack (located on the motherboard...)....and you are shorting out from loose contacts on the DC Jack...
The DC PowerJack Will either have to be desoldered and cleaned then Resoldered.....
Or Purchase a New DC Jack and Replace With Old By Desoldering and soldering New in Place....
And of course.. get yourself a new charging cord, or go to radio shack and buy a new plug tip and reattach it to your Power Charger Cord End....
Hope that helps..
Jun 13, 2008 | HP Compaq Presario C500t Notebook
Making funny clicking noise and hour glass showing that it is processing won't go away
As a follow-on to solution 2 (thanks for the post BTW), I found the problem is indeed the light bar, but rather than breaking into the printer to move and lube the light bar, I found success by simply shaking the printer with the left side down, to move the light bar along it's track to the left. (the shaking motion is sort of like getting ketchup out of a bottle).
This worked better for me than dismantling the printer with a special screw driver and seemingly needing to break the panel to get to the third screw. Hopefully this helps.
Oct 11, 2007 | HP PSC 2510 All-In-One InkJet Printer
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
