Question about Canon PowerShot S230 / IXUS 179 Digital Camera
Wierd image When I view a photo already taken there appears in the upper rt. corner of the view screen what looks loke an up & down white bar grape & numbers above it, such as 102-0238. Thanks for help. A
  • Allan J. Ahearne Feb 16, 2007
    JMuskovitz solved my problem. Many yhanks. Allan J. Ahearne, Cooperstown, NY
    Scholar:
  • 135 Answers
This is a "histogram" showing you some information about the brightness levels of the photo. You can press the "DISP" button to toggle between three views -- full details(what you are seeing now), limited details, and no details.
Posted on Feb 16, 2007
SOURCE:
Set Date and Time Display to FinePix T410 Camera
The date and time appear in the lower-left corner of the screen, both when taking pictures and when reviewing pictures you've already taken.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Apr 06, 2014 | Fuji Finepix T410 Black 16mp Digital...
I cannot look back my photos i have taken on camera
Press the MODE button to enter the playback mode. A right-pointing triangle will appear in the upper-left corner of the screen.
Full details are in the "Playback Mode" section of the manual, beginning on page 14.
Jul 31, 2011 | Vivitar ViviCam 5024 Digital Camera
SONY DSC T33 SCREEN STOPPING SHOWING. CLICK SONY DSC T33 SCREEN STOPPING SHOWING. CLICK BUTTON,FLASH WORKS AND IT APPEARS TO TAKE A PHOTO BUT NOTHING SHOWS. ALL ISONY DSC T33 SCREEN STOPPING SHOWING. CLICK...
This is due to failure of ccd imager chip in your camera, replace ccd imager chip to get live view in lcd to take fresh pictures.
Let me know if you need ccd imager chip part number.
Sep 28, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
Picture suddenly pink
It is known problem of bad ccd imager in Sony DSC-T1 camera and ccd imager chip will be replaced to get normal live view in camera mode.
Sony will repair it free of cost so click Sony CCD Imager Support for details.
Thanks.
Sep 22, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
I downloaded IE 7 now my menu bar for tools,find,view,ect,cannot be seen on my computer, most of my information at the top of the page is gray
Hi there.
Click on the Tools menu, located in the upper right hand corner of your browser window. When the drop-down menu appears, select Menu Bar.
You should now see the Menu Bar displayed in the toolbar section of your browser window. To hide the Menu bar, simply repeat Step 2.
Thanks for choosing FixYa!!
Jun 02, 2009 | Dell Dimension 1100 PC Desktop
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Samsungscd23/blank viewscreen for photo memory stick
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Aug 01, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Canon PowerShot S230 / IXUS 179 Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
