No green color on display. All updated drivers and monitor is good
    Novelist:
    Scholar:
  • 85 Answers
If all drivers are updated and you are positive monitor is ok then it must be the connection in between (video cable) or there is a slight chance the video card is gone bad.
I would try a new video cable first
Try reseating the video card in the slot on the board (take it out and put it back in)
Try the monitor on a different PC if possible with the same cable you are using on yours.
If monitor works fine on different pc and cable is good then also try different video card if possible (even if yours is not old) I’ve seen new cards suddenly have problems for various reasons everything from video cable had a little to much tension on it and the solder connections on the video card came loose all the way to the card just decided to quit working from some sort of defect so I wouldn’t rule out the possibility.
But the most common reason for the problem your having is usually loose connection on back of monitor or PC or bad video cable.
Posted on Dec 06, 2008
Screen keeps flashing green-blue-red
The manual for the monitor can be found here (
Mitsubishi DiamondPoint V50LCD User Manual ) The specific Red Green Blue cycle isn't noted.
  1. I'd start with toggling on the on screen set-up display. if that comes up and is legible, then you know that the screen is working.
  2. What is your video set up to push to the V50? If it's not a supported resolution, the display may respond this way. try downgrading it something like VGA (640x480) and see if that works. (The max resolution shown in the manual is 1024 x 768, so don't go higher than that. It's also 24 bit color (8 bits each for R,G,B, so don't try to push 32 bit color to it)>
  3. Set the output to your primary monitor to 1024 x 768, thousands of colors. Make sure the monitor sees it OK. Now you know the first monitor and cable are OK. Now switch the cable to the V50 monitor. Do you get a signal now? Then the display works. Try putting your primary display on the second cable. Does it pick up anything now? No. Maybe a bad cable.
  4. You can try swapping the cable going to the V50 to go from your primary monitor output port on the computer to your primary monitor. if the primary monitor works OK, then the cable is good.
  5. Depending on the computer system you're on, make sure that you at least have a generic monitor driver installed for the V50 output. Ideally, get the driver for the monitor You can get the driver here (
Mitsubishi Monitor drivers ) amongst other places.
Nov 11, 2015 | Mitsubishi 15" Diamondpoint V50lcd-Bk Lcd...
Picture on Monitor has shadows and is blurry and colors are mostly blue, green, purple. Print (text) is okay. Any solutions? Thanks
Did the problem occur out of nowhere? Is it a new monitor and was like that from the start? Is it an old monitor? Laptop? LCD? There isn't enough information.
However, try setting all video settings to default or "recommended". If that doesn't work, be sure your video card and display drivers are updated.
Oct 18, 2013 | KDS Computers & Internet
Green horizontal lines on display
First thing to try is another HDMI cable and see if this fixes the problem. Seen a bad cables way too many times...
Second: update your videocard to the latest drivers:
You can find the correct drivers @ AMD support. Click the link and choose the correct settings. Then click display results. Download & install.
Third thing you could try is another monitor. Even a new monitor can be broken. Not uncommon. If another monitor has a good image then return your new one and let them give you a good one
Oct 17, 2013 | Dell Computers & Internet
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Screen now is pale green and print is fuzzy
You are probably right. The inverter supplies the voltage needed to light up the screen and power the lcd. If I were to tackle this repair I would sub a laptop monitor in place of yours and then troubleshoot the monitor. Inverters have a fairly high failure rate
Apr 22, 2010 | Dell Inspiron B130 Notebook
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Mar 19, 2009 | Gateway FPD1760 Monitor
Emachines T6524 has lost green color in monitor
this is a internal problem with the display. you need repair
Feb 05, 2009 | eMachines T6524 PC Desktop
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
1 monitor is red - 1 is green
its because when you start putting to many moniter spliters the color data gets lost in the link.
Sep 12, 2008 | Matrox 128 MB G450 Quad Graphic Card
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
