Question about Compaq Armada E500 Notebook
FROZEN IN PREPARING TO STANDBY
Fronzen in preparing to standby
    President:
  • 2,110 Answers
Having a wide variety of 3rd party applications could be your problem
no doubt, just because you might not use over half of them. As for
"log" files, you should check the "Event Viewer" to check to see what
could be conflicting with your system.
To get to this point:
>> Goto Start>Run>Type eventvwr
>> More thank likely it will be in "Application" or "System" that will
tell you what is wrong.
Another option that might help is making your paging file bigger, even
though you do have quite a great amount of RAM installed, so I'm not
really sure that this would fix your problem. If you would like to
experiment with this though, here are the steps to make changes to
your Paging File. One note: your system defaults your paging file at
1.5 times the ammount of RAM currently installed on your system.
>> Right click "My Computer" and go down and click "Properties"
>> Click the "Advanced" tab
>> In the "Performance" area, click the "settings" button
>> Click the "advanced" tab
>> At the bottom in the "Virtual Memory" section, click "Change"
>> Select the biggest drive on your system (if applicable) and enter a
bigger number, such as something about 3 times the ammount of RAM
installed on your computer (make sure you have enough disk space), you
will select the drive first and then in the "Custom Size" options, put
the initial size (MB) in the text box and the MAX size, in which it
will not exceed this amount of space. you must click the "Set" button,
or your options will not be saved.
>> make sure that if you have selected a different drive that you
select the old drive that still has the old paging file and delete the
paging file for that drive. to do this just select the old drive and
click the radio option button called "No Paging File". and then again,
click "Set" to make sure the changes are applied.
>> click ok until you are done.
Posted on Dec 06, 2008
    Sergeant:
  • 399 Answers
Charge the unit againn.also remove the battery from the back and reinsert again.also shut off for sometime and then start.
    Genius:
  • 3,422 Answers
HI,
Please press and hold the Power button for a hard-boot.
  • Priya darshan Dec 06, 2008
    This will reset and fix the issue.You can also remove the battery from the back and then reinsert it again and turn on your Laptop.
    Let me know the result.
  • Compaq Master
  • 13,433 Answers
Unplug the power adapter and remove the battery, wait 10seconds and you can plug them back in and the laptop will work normally.
My computer is frozen on Preparing for Standby. I have tied to hold down pwerkey. I have tried ctrlaltesc and ctrlaltdel What sshould I do?
unplug the power and remove the battery. after it shuts off put the battery and power back on .. reboot to safe mode then after it boots up successfully reboot normally
Aug 21, 2010 | Toshiba Satellite A100-S8111TD Notebook
My computer is frozen on preparing for stand by. Wat should I do? The mouse works. I have tried pressing and holding down the power button Have also used ctrl alt del and ctrl alt esc all at once
Hold the power button down for more than 5 seconds and this will force the computer to shut down, if that fails, which it shouldn't, but if it does as much as i don't want to recommend this, unplug it, this will ensure the shutdown. Also get some sort of antivirus to check and see if there is anything impeding the standby, I recommend Microsoft Security Essentials paired up with Malware Bytes to ensure no viruses eek there way through your system.
Aug 21, 2010 | Toshiba Computers & Internet
PC Freezes when going to Standby
all else fails unplug for 3seconds that will unload the capicator and plug it in again and that should fix it
Nov 16, 2009 | Dell Dimension 3100 PC Desktop
My Element 32 is frozen in standby... won't turn on!
blown caps in power supply they will be puffed up on top easy fix
Sep 17, 2009 | Element Electronics FLX3210 32 in. LCD TV
Standby mode is not working..
goto control panel and double click on "power options" under that aplet is the settings for standby and also hibernate.
Dec 07, 2008 | Computers & Internet
Frozen
Bring it back to your store there is nothing to do with it anymore
Jun 29, 2008 | Coby MP-C7085 MP3 Player
Keyboard problem
Are you running XP if so try to uninstall in safe mode by press the F8 key at startup.
Oct 17, 2007 | Acer Aspire 5100 Notebook
Compaq Armada E500 Notebook Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
