Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
Photos are dark halfway across as if something was blocking lens.
Shots look ok except as if a hand was blocking part of the lens when there's nothing i can see in the shutter that is....
    Scholar:
  • 185 Answers
Take the lens off and charge the shutter. with the film door open hold the camera toward a light. Fire the shutter and if you see half light in the film window the shutter magnets need replaced. Or the shutter is not being charged enough. If so,camera must be disassembled by a repair shop.
Posted on Dec 06, 2008
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
Sony cyber shot camera lense stuck halfway.
    According to the symptom your camra needs replacement Lens block, It is due to malfunctioning of zoom motor. The part No along with description is given below:
1-788-363-11     OPTICAL UNIT
  Replace the unit with new one and it works fine again.
  Thanks for using fixya.
Oct 31, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Everything is so dark!
If the camera is working properly with other lenses, then you have a problem with that lens. In M, you can set the aperture yourself, and the photos come out properly exposed. When the lens is set to auto, apparently it is going to minimum aperture and not responding to the camera's 'instructions'. The thing that makes me think so is that you say everything looks dark through the optical viewfinder. Normally the aperture stays full open so you can see and compose your shot, and only stops down to the correct aperture when you actually take the shot. I would suggest having the lens checked by an appropriate camera service shop.
May 29, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Error E1600 - please help!
The lens drive has failed for any one of many reasons- nothing for you to do here except to get onto Sony customer support Be warned however - the likely cost of repair will be near the price of replacing it.
Jul 30, 2007 | Sony Cyber-Shot DSC-P150 Digital Camera
Sony Cyber Shot DSC-L1 Digital Camera
Sounds like a jammed lens block assy.Does lens make any attempt to open??.Did camera get a knock or fall.Not much you can do but send for repair,Would advise get estimate before proceeding with repair.,
May 20, 2007 | Sony Cyber-Shot DSC-L1 Digital Camera
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
113 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
